Picture this....hint hint, i made it up in Geograpy class
You just finished installing your z Holly distributors and your Edlebrock headers. But there is one thing you wish you had. A Blower. You slam down your hood and start up you 61 Catalina. It sounds like thunder. You peel out of your driveway and off to your local dragstrip. You up against a 55 Bel Air with a 375 and spitfire headers. As you pull up to the line, engine roaring, heart pumping. You squell you tires trying to intimidate your opponent. The light flases green, your reaction time is perfect. You burst ahead of your opponent. As you flare down the raceway, you feel your Speed Por injection Explode as you come over the finish line. But you still had enought speed to cross the line. With a few bucks that you had in your pocket, you go and buy a new Injection system. With the help of some other racers, you install your new injection system and are ready to go home. You glance in your catalog and realize you dont have enought for your blower so you put up another challenge. A 36 Willy's picks up the challenge. He is equipped with a 409 and 5.78-inch intake lift. You do the tire squeel again and the small crowd goes nuts. You rev up the engine. As the light turns green, you lift your front tires off the ground and pull ahead of the Willy's. But the 36 is not finished. You glance over to see the bright yellow flames painted on the side of the car, you soon see the front window. Your eyes go back to the road. Your foot slams to the floor and you pull far ahead of the 36 Willy's and over the fiish line. Another victory! You take the $4000 you won in this race and drive home. You look into your catalog at the 375 with a blower. You pick up the telephone and call, order and give a roaring "YIPPIE." You hag and lay down. Your finally going to be able to build you ultimate racing maching.THE END
HRK <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
