Pictures of hair pins help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2012, 11:08 PM
Last journal entry: Getting there....I think
i want to mount my front hair pins in the center apposed to welding a bracket under the frame. any pics on how you did yours?? thanks guys!
Old 04-15-2012, 10:00 AM
Wiki Edits: 27
hairpin mounts
Usually hairpins were used when lowering the front end , changing engines and there was not enough room for the stock ford type parts , what kind of car-chassis are you planning to build. ? gasser type.. high rider. ? ?
Old 04-15-2012, 10:54 AM
Wiki Edits: 49
When building my deuce I also didn't want to weld on a lower mount for the hairpins. What I did was box the frame, drill through about an inch or so up from the bottom and then I welded in a piece of thick wall tubing with an ID slightly larger than the bolt. Finished the inside and outside with large washers and a little filler to clean up the weld and make a nice fillet. They mount securely to the frame and I think they look pretty good.
Inside
Outside
Mounted
Centerline
HotRodsAndHemis.com
Hotrodders.com is now an AutoGuide owned forum. HEADS UP GUYS.... TAMPON ADS ARE ON THEIR WAY!!!
Evercoats: Fiber Tech, Everglass, Kitty Hair, Tiger Hair, Metal to Metal rusty428cj Body - Exterior 5 02-12-2013 03:49 PM
hair style 406chevelle Off-Topic 4 06-10-2006 01:01 AM
Pulling my hair out! cool rockin daddy Body - Exterior 3 04-14-2006 03:53 PM
Just about to rip my hair out StevenC Engine 23 10-23-2005 12:34 PM
More kitty hair ... Vesimies Interior 6 08-10-2004 10:17 PM
