Pictures of Heater/AC unit under fender or in trunk - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2012, 01:08 PM
Mutt's37Buick's Avatar
I would like to use the heater and AC out of my '95 Roadmaster in my '37 Roadmaster.
I think the unit will not mount under the dash because there is not room.
I have read of others mounting an AC condenser under the front fender or in the trunk. I have not taken the unit out of the donor car yet.
I apologize if these questions seem fundamental, I just have no experience working on car heaters & AC.
1) When remote AC is added, is it a heater + AC, or just AC?
2) Has anyone used AC from a donor car mounted in a remote location?
3) Can someone share pictures of such a set-up and mounting.
Thanks
Mutt
Old 04-30-2012, 08:55 PM
Wiki Edits: 27
under seat heaters
50's Buicks and I think Cads had and under seat heater unit as an option. I had one. they were popular to add and aux heat under your truck seat , the reg heater melting the snow off the windshield and the under seat to keep you from freezing. You might be able to have 2 separate fans and units one heat and one cool where they will fit. look at pieces from a van rear seat heater or heat cool.
'95 Roadmaster steering in '37 Roadmaster Mutt's37Buick Suspension - Brakes - Steering 0 03-19-2012 04:40 PM
'95 Roadmaster Donor for '37 Roadmaster Mutt's37Buick Hotrodding Basics 5 03-12-2012 08:47 AM
Minimum fender clearance '37 Buick Roadmaster Mutt's37Buick Hotrodding Basics 5 09-30-2011 08:13 AM
Tire Cover as Fender?(cycle fender), Need Bracket Ideas! Fred A Body - Exterior 1 01-29-2006 02:46 PM
Pictures of Fender Patch Panel DILEMNA! unstable Body - Exterior 15 03-05-2004 03:20 PM
