Pictures of project - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2004, 10:08 PM
New Member
Pictures of project
I have uploaded some pics of the Ford Starliner im wanting to restore,you will find them in my gallery. these are for me to reference back to as i progress. thought you all might want to see what im going to be working on. Give some thoughts,im always up for sugestions.
Should i worry about the trunk bottom and under the back seat as far as what i weld in? i thought about just fixing the rust with sheet metal and moving along since those areas will be covered up and unseen. of course i will be doing as neat a job as possible,but finding pans is turning into a real job.
Also this car has a real thick layer of undercoating on it,i would really like to remove it,any good way of doing this other than pure old manual labor scraping?
Old 03-07-2004, 01:35 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
nice ride man, should look sweet when its done
best bet for floorpan on a car that isnt being restored concours is to hit the junkyard and gut a nice clean floor out of something ay newer and weld it in, doing this is way cheaper then replacement floors and the stamped lines in the panel give the floor WAY more strength too
easiest way to strip undercoating is to get the floor hot w/ a torch and scrape the coating free ... goes alot faster then just using elbow grease alone
later
Nick
Old 03-08-2004, 08:59 AM
Thom Laybourne's Avatar
Nice Ride
You are going to like that ride when done. Just saw a finished one here in Temecula, CA. NICE. Find sheet metal place and get 4' X 4' 18 Gage sheets. You can roll them using cinder blocks and the drive shaft as a big rolling pin. I just did the entire front floor pan in mine and drivers toe board. It took me 6 weeks. EastWood www.eastwoodcompany.com has several hand tools that are great for you project. They also have a spray for removing the undercoating. I just used it on my 52 sedan and it works great.
hr41pearl
