pig tail conversion
i have 90 chevy c1500. It came with standard trans I put 700r4 trans in it converted it to automatic but the pig tail for the lockup i don't understand one of the pig tails pull off from the 5 speed trans is a 2 prong plug it doesn't go anywhere on the new trans but i do not have pigtail for for lock up
i pulled the trans off a camaro with pig tail i was hoping to tie the wires in instead of buying kit
You need a way to shut off the lockup. You can use a switch but you will forget when you tromp on the gas or pull off the highway.
I'm not sure if the ECM on a standard vehicle has provisions for lockup function. You would need to compare wiring diagrams to know for sure unless someone here has done this and can chime in. |
thanks for help ill keep looking and see what i can find out
| tail lights | sapsz28 | Body - Exterior | 2 | 04-29-2009 07:54 AM |
| third tail light help | 49fordp/u | Body - Exterior | 5 | 01-10-2008 07:24 PM |
| Tail Lights | Tanmar1 | Body - Exterior | 3 | 08-29-2006 03:17 PM |
| tail pipes or no tail pipes? | 92camaroZ28 | Engine | 13 | 01-12-2005 11:58 PM |
| LED tail light conversion | zonk | Electrical | 14 | 01-24-2003 12:20 PM |
