Pillar Foam !! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 05:56 PM
Pillar Foam !!
Can Anyone Comment On 3m Pillar Foam. This Stuff Any Good
Thanks
Donzie
Old 02-06-2006, 08:34 PM
Well depending on what you are after. There are a few foams, the Pillar foam (#08457) which is rigid and Flexible foam (#8463) which is..well....flexible.
The rigid is I assume a "structual" foam that adds rigidity and believe it or not adds to the roll over strength of the roof. The flexible is strictly for sound deadening.
I have to say, I use them both at work in general collision repair replacing the factory rigid and flexible foams used in assembly.
I think they are a neat tool to further improve the sound deadening and rigidity of the body.
I will be using both in my 1948 Chevy pickup after the top chop is completed.
Old 02-07-2006, 03:29 PM
S10xGN's Avatar
Gotta love a turbo!
WAIT, WAIT, WAIT! Wasn't there a thread (or three) here just a few weeks ago bashing the use of foam(s) for holding moisture and causing rust? And now it's OK? Hmmm.
Russ
Old 02-07-2006, 03:53 PM
adtkart@aol.com
I believe that the foams that Brian is talking about are 2 part foams that set real quickly. They are put in pillars and such, where there should normally be no water going.
Aaron
What thickness of foam for Door Panels? (KristKustoms???) mistermuscles Interior 24 03-30-2006 04:36 PM
fuel cell foam Vortech 4.3 Engine 6 12-27-2005 07:42 AM
Fiberglass interior using foam..... Jackyl666 Interior 8 07-28-2005 11:23 PM
A pillar bluebu Body - Exterior 2 04-02-2005 05:27 AM
Foam foam and more foam Halloweenking Interior 20 06-07-2003 04:34 PM
