Pilot bearing: bronze or rollers?
Do the roller bearing pilot's wear out faster than their old skool bronze counter parts?
That depends on the life they lead. A roller would not do as well in an off road situation where you are running through deep mud and water.the graphite inpregnated bronze would do better there.A roller is almost a must on street performance as a lot of new design transmissions are built to close tolerances and the bearings maintain that well.The rollers are "Kinder" the the bearing area of the input shaft as well ,which can result in longer, better performance and less wear on the shaft at the bearing contact point.
Ah good points. This is just a weekend street rod truck, no strip, no race, no offroad use. Old gen 1 SBC350 with a (freshly rebuilt) old B/W super T10. So none of that new high tolerance fancy stuff your talking about! Lol
Yeah for the street if the pilot shaft portion of the trans input is pretty decent I would run the bearing style. The bronze is pretty forgiving if there is a wear issue in this area. If there is no visible wear on the pilot part of the shaft run the roller.If it is worn run the bronze.
For the application- "a weekend street rod truck, no strip, no race, no offroad use. Old gen 1 SBC350 with a (freshly rebuilt) old B/W super T10", I'd use a quality bronze oilite-type bushing. They've served well for many, many years, they're the epitome of efficient simplicity, they're capable of 100K miles- plus durability, and I'd not hesitate to use them in any application that originally used a bushing and not a rolling element bearing of some sort.
In applications that call for a roller, of course I would say to use one. Post on bushings/bearings- HERE. |
Wow. That thread was very enlightening. It seems the roller bearing was a fix for a problem that never existed...I dunno maybe the new LS engines need 'em. But my B/W ST-10 was never designed for a roller...so bronze it is. Thanks for posting Cobalt!
as mentioned above, go with the "NON MAGNETIC" bronze bushing. the bushings that are magnetic have too much iron in them and will wear the nose of the input shaft.
forget the needle bearing pilot bearings, clutch dust kills them and when the needles/rollers go they will take out the nose of the input shaft. a NON MAGETIC bronze bushing is the ONLY way to go. i have replaced thousands of clutches and trust me, the bronze pilot bushings are the only way to go... |
pilot bushing
As I mentioned in the thread that Mark referenced, the bronze bushing makes better sense. My friend who owns a transmission shop says that while the roller bearing maintains precision pilot shaft alignment, its only good until it breaks. When the roller bearing fails, they always seize, which always ruins the input shaft requiring a transmission repair to replace it. While the bronze bushing may not maintain as precision an alignment, it does the job nearly as good and is sacrificial thus saving the input shaft from damage. He replaces all rollers with bronze when doing clutch jobs(and alot of bad input shafts in the process).olnolan
| GM pilot bushing and roller bearing I.D. #'s | greenmoonshine | Transmission - Rearend | 30 | 07-07-2010 06:29 AM |
| SBC Pilot Bearing | Brian's56Chevy | Transmission - Rearend | 1 | 07-04-2007 08:23 AM |
| Pilot Bearing Problem | shad88 | Transmission - Rearend | 4 | 11-01-2006 09:26 AM |
| Pilot bearing install | Zeder | Transmission - Rearend | 2 | 11-14-2004 04:09 AM |
| Stuck pilot bearing in 350 sbc I got it! | zachscc | Engine | 3 | 12-23-2002 05:48 AM |
