You keep saying bearing, is this a bearing or a bushing? All the 283s I worked on used a bushing made of oillite and bronze, some will peel but for a tight fit they always worked. Good Luck
I used to have an old 283 crank that had a slightly smaller hole in the back side, so a normal pilot bushing wouldn't fit. An old car guy told me you could get a bushing that would fit it, but I had another crank with a normal-sized hole, so I just used that one. Might check with a parts place that has a paper catalog with bushing dimensions, just in case one's still available.
Here is a spiffy link to the part of dorman's website with pilot bushings. RIGHT HERE
If you click on the part number of a bushing it will give you dimensions. You may have to click a few part #'s to find it. hope this helps, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Puzzling temperature problem on the hemi solved | Centerline | Engine | 2 | 11-26-2004 03:48 PM |
| 4th Throw-out bearing...Frustrated! | Valkadesh | Transmission - Rearend | 10 | 11-22-2004 09:56 AM |
| Cam Bearing Oil Hole | DTL504 | Engine | 2 | 03-05-2004 10:39 PM |
| s-10 carrier bearing, how do you check them | catscan4free | Transmission - Rearend | 2 | 01-24-2004 04:45 PM |
| pilot bearings in slant six | hipo225 | Transmission - Rearend | 3 | 12-01-2003 04:59 PM |
