Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pilot Bearing / Solid or ballbearing type"whats best to use"
Old 01-06-2007, 05:54 AM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by x711
Poncho, I believe your right on this.. The Original one looked ok prior to my hacking. I think the bearing type is a weak link and would just hate for it to go out !
Over time the grease in the bearing type will disappear due to heat. a little bit
of grit could get in there and puff games up !, bearings get destroyed ..
Thanks...X711
personally i take the bearing over the bushing everytime... the bearing has a lip seal on 1 end to keep the grease in if installed correctly, and 2nd, i never grease a bushing, ull be pulling it back out in months if u do... the bushing needs to be impregnated with atf. ( u can actually see the fluid come out the sides. use ur finger to plug the center, take a cup with fluid and pour in hole till at top, then use ur thumb to press..) it will last either way with good install practices.
