pilot bushing - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2008, 09:53 PM
pilot bushing
Hi guys, got a problem. I can't get the pilot bushing(bearing) out of my kids 302. Tried the slide hammer and all I did was bust up the inner race. I have heard of the grease method but if a slide hammer couldn't get it out I doubt the grease method would work. Anybody else have the same problem?
Old 09-23-2008, 10:26 PM
If you have the correct size shaft, the grease method should work. The hydraulic force you can create with the grease is considerable.
Old 09-23-2008, 10:39 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
The grease method works well if you can get a tight fit. If you cant find something that fits well, get a piece of metal LARGER than the hole and grind down its diameter carefully on a bench grinder (rotate it in your hands against the grinding wheel) until you get a perfect fit.
Another method is to use a 1/8" dia carbide burr in a dremel and slice through the wall of the bearing race, you shoud be able to fish it out after doing that just try not to grind a groove into the crank
Old 09-24-2008, 03:51 AM
SSedan64's Avatar
Pilot Bushing Puller
The last time I tried the grease method it didn't budge and I had a used trans shaft. Here's a tool I ran across from Springer Tool about the best $20 bucks I've spent. Saw it in CarCraft mag also.
http://www.springertool.com/Function.html
http://www.springertool.com/Tech_Info.html
Old 09-24-2008, 06:08 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I don't know what size the Ford innner hole is, but on a Chevy, I use a 3/4" coarse tap and just run the tap in until it bottoms out, and then it pulls the bushing right out. Fast & simple.
Old 09-24-2008, 07:05 AM
Last wiki edit: Removing stuck fasteners
pilit bushing
F&J
I think what you described would work with a bronze bushing, but not with a bearing which is hardened. The tap would break if it ever screwed into the bearing inter race. He did say bearing and not bushing I think. I've used what you're describing to remove the starter bushing on VW even if the bushing is worn en egg shaped. Just use a tap a few thousands larger that the shaft (.020 or so) It'll start turning easier once it gone through the bushing until it hits the bottom of the hole then it'll get harder to turn. If it doesn't start pushing the bushing out with a little force, don't force it to hard because the block is alum. I believe. lol
Old 09-24-2008, 01:00 PM
fast68's Avatar
likes chevy trucks & boobies
grease method has always worked for me well i have an actual input shaft from an old tranny laying around that i use
it doesnt fit really tight but works anyways
within about 5 or 6 smacks the bushing is out
pack that hole all the way with thick grease and smack the shaft or a rod etc in there a few times
maybe add some more grease
repeat
should be out of there then
good luck
Old 09-24-2008, 02:55 PM
justold's Avatar
sounds like all that is left in the crank is the bearing race , if so just lay a bead across it with your electric welder in two places let it cool and it will fall out .
Old 09-24-2008, 07:15 PM
Thanks for all the suggestions guys. I'll let you know what works.
Pilot bushing SBC and ST10 68chevytrkr Transmission - Rearend 2 02-22-2008 07:04 AM
Sway Bar bushing blues bowtyebob Suspension - Brakes - Steering 6 11-27-2006 05:58 AM
trans tailshaft bushing fit cboy Transmission - Rearend 8 04-20-2006 09:31 PM
How to remove pilot bushing? 70bird Transmission - Rearend 8 07-27-2004 10:42 AM
How to remove pilot bushing? 70bird Suspension - Brakes - Steering 2 07-26-2004 10:56 PM
