pilot roller bearing for t56 in 99 vortec motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2009, 05:29 PM
71 camaro with stock 350 trans. I got a good deal on a T56
a few days ago. I am going to stab this in the car.
Is a roller pilot bearing the best to get? Should I get one
for the 93/97 Lt1 application?? Or how do i know what I
need for a 99 block. I know the flywheel from The Lt1 works
with this motor Thanks
Old 07-17-2009, 08:04 PM
BUMP Help
Old 07-17-2009, 09:48 PM
IIRC the input shaft will be 0.400" longer than the lt1 version, Are you sure that the lt1 flywheel will fit, I thought they were the different pattern like the one piece seal gen 1 sbc's have.
Shane
Old 07-18-2009, 06:31 PM
Shane
T
The 99 block has a one piece seal like the 93/97 lt1 blocks.
Old 07-19-2009, 02:21 PM
I was thinking that the spacing was slightly different,maybe not. LS x engines crank flange is flush.
Shane
Old 07-20-2009, 08:18 PM
Anyone??
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
Pilot Bearing Problem shad88 Transmission - Rearend 4 11-01-2006 09:26 AM
Pilot bearing install Zeder Transmission - Rearend 2 11-14-2004 04:09 AM
pilot bearings in slant six hipo225 Transmission - Rearend 3 12-01-2003 04:59 PM
Stuck pilot bearing in 350 sbc I got it! zachscc Engine 3 12-23-2002 05:48 AM
