pin holes in weld after welding new metal in under rear window - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-15-2006, 11:14 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Steve,
I have a Lincoln 175 Mig and a Lincoln Precision Tig 185-I use the Mig about 80% of the time, and if I had to pick just one, it would depend on what type of work I was doing-if I were doing primarily restoration body work, I would get the 185 Tig, and, you are correct-it does take longer, but the welds are beautiful. For everything else (including a lot of body work), I would get a Mig-
By the way, yes, you can Mig aluminum-
  #17 (permalink)
Old 06-15-2006, 11:20 AM
The Twenty Gauge is a cored wire but it is a true MIG wire (M-etal I-nert G-as) and runs best on a 75 -25 mix (C/25 as it is commonly known) and it is not to be confused with the gas-less flux core which is a completely different animal altogether. The JW Harris site says it can be used with straight CO2 but I have found it really needs the C25 to work right but C25 is what you will want to use with any steel MIG wire. Yes you can weld aluminum with a MIG just fine however the thinner stuff welds a lot better with a TIG and really TIG is probably better all around for aluminum. To weld aluminum with MIG you simply change wire and switch to straight Argon gas but it is a bit different so practice first before tackling anything valuable. I have talked so much about that Twenty Gauge wire that it is starting to get a little embarrassing but honestly in all my years of chasing that little blue light I have never seen anything that even comes close to what it will do on thin sheet and it is much easier for a novice to weld body panels without burn through or warpage than with solid wire.
  #18 (permalink)
Old 06-15-2006, 04:20 PM
Will I ever get it done?
Last journal entry: Hood
On my MIG, you have to put in a teflon sleeve so the alum. wire doesn't hang up. You also have to run pure argon (IIRC). Never tried it (yet).
  #19 (permalink)
Old 06-15-2006, 06:38 PM
Using a Lincoln Weld Pak 100.
I Started with the .035 flux cored wire and man that was tough to weld that thin metal patches. Then I bought the conversion kit to change it over to MIG and now use the .023 wire with the 75 25 gas mixture and I will never go back. What I like about the MIG is it really leaves less splatter and you can really lay some flat welds. I know some guys though that with the flux cored can lay some weld lines that look like glass. What I have had to learn over the year is how to dial in for different types of butt welds I've done and have really enjoyed the MIG. Now one question I do have is, is TIG easier to use to create flat penetrating welds?
MP
  #20 (permalink)
Old 06-16-2006, 07:22 AM
35WINDOW's Avatar
IMHO,
I don't know that I would say easier-I would say it's more controllable. Since you have a foot pedal (or Handamptrol) you can change the amount of heat (Amps) into the Weld on the fly, so with practice, you can stay just on the edge of burn-through easier. If you can Oxy-Ace Weld well you can Tig-it does take a lot more practice (at least it did for me) to Tig, and on sheetmetal it is a smaller weld (I use .035 rod).
Again, if you are going to do fine, no-bondo kind of work, Tig welds are a little easier to planish than Mig welds, so it appears there is a new debate: does it take longer to metal finish a panel with Tig (slower welding, easier to "hammer-weld", and for me, a larger HAZ), or a Mig Weld (Faster, harder to planish, usually easier to burn-through). For brackets and such that I am not going to grind the Welds on (and my Buddy's will see) I Tig (looks Better). For mocking things up, or quick "get it done" type of stuff, I Mig-
  #21 (permalink)
Old 06-16-2006, 11:08 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
My Lincoln 175 MIG will do aluminum with the "kit" and I believe it requires 100% Argon. Never tried it though.
  #22 (permalink)
Old 06-19-2006, 11:10 AM
pictures of my repair
Here is a couple pictures of my repair effert. I hope it doesn't look too bad for a novice. I have it sprayed with some cheap butt rattle can primer for now. I have some epoxy and some filler for later.
Any comments or suggestions are greatly appreciated.
hope this worked
ID:	12848   Click image for larger version
Name:	hole repaired.jpg
ID:	12849   Click image for larger version
Name:	hole repaired 2.jpg
  #23 (permalink)
Old 06-19-2006, 12:14 PM
Something to keep in mind as you approach the job.
If you do not seal the back side of a pin hole and you put bondo on than you risk long term swelling of the bondo as it absorbs moisture through the hole.
I would be sure to epoxy prime both sides and be sure the pin holes are filled.
  #24 (permalink)
Old 06-19-2006, 01:14 PM
PIn holes look like they are gone. I'm thinking that I might try to get a brush behind the panel and put some eastwood rust encapsulator on the back side.
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 08:47 PM
welding a metal cowl hood scoop to a metal hood? project66 Body - Exterior 7 11-10-2004 10:25 AM
53 ford f100 rear window tgregoire Body - Exterior 1 07-16-2002 06:20 PM
