I have changed brakes on a BUNCH of GMs and never pushed the pin. I always wondered what that pin was for. Guess that come from never reading instruction manuals!
I believe the pin is and indicator related to brake failure in one of the circuits of the dual system.
well, after a bit more searching (lucky I have nothing to do at work at the mo), in normal driving the proportioning valve supplies equal pressure to each wheel at gentle braking then splits 70/30 front and back under heavy braking
when bleeding, the mechanism that allows equal pressure to all wheels gets confused and cuts off supply to the front brakes meaning you can't bleed them, the pin stops this from happening. Now, the pin locks the proportioning valve in one of 2 positions; either locked in the 50/50 front/back, or the 70/30 front/back I'll take the car out for a spin after I get home and bleed them and I should be able to tell pretty quickly which one it is. |
It occurs to me that somewhere in my dark past I read an instruction sheet or shop tech article that said for some cars,after installing a bench-bled master cylinder or breaking into the system, you should stomp the brake pedal several times before bleeding and adjusting. Perhaps this how the valve is centered on some vehicles without the exposed pin?
Worth a try, can't hurt. |
[quote]Originally posted by andybird:
<strong>well, after a bit more searching (lucky I have nothing to do at work at the mo), in normal driving the proportioning valve supplies equal pressure to each wheel at gentle braking then splits 70/30 front and back under heavy braking when bleeding, the mechanism that allows equal pressure to all wheels gets confused and cuts off supply to the front brakes meaning you can't bleed them, the pin stops this from happening. Now, the pin locks the proportioning valve in one of 2 positions; either locked in the 50/50 front/back, or the 70/30 front/back I'll take the car out for a spin after I get home and bleed them and I should be able to tell pretty quickly which one it is.</strong><hr></blockquote> Thanx for the tip! |
my problem is that the pin is rusted "in" so it's always in the in position (although I though it was the other way at first as I don't have a new one to compare against),
but driving the car, it seems to be stuck in the 70/30 position so that's ok (at least till the new one arrives anyhow) |
Thanks to Hotrodders.com, I learn something every day. Our hot rodding Buds (Mates) across the way sure can make us get back into the books with their "forced" research!!
Thanks Andy. Trees |
well needs must when the the devil ****s on your cornflakes,
and I need to make sure I have the stopping power to offset the new found 411 lb/ft of torque although I am becoming increasingly glad of this here intermernet thingy, I contacted a UK supplier of american car parts and they wanted roughly $200 for the valve and it would take 2-3 weeks to arrive (because they wanted to just put it in their next container that was due to come over), I contacted yearone.com, valve = $76, postage in 3-5 days = $36, plus taxes = $133 bargain! [ April 17, 2003: Message edited by: andybird ]</p> |
<strong>well needs must when the the devil ****s on your cornflakes, and I need to make sure I have the stopping power to offset the new found 411 lb/ft of torque although I am becoming increasingly glad of this here intermernet thingy, I contacted a UK supplier of american car parts and they wanted roughly $200 for the valve and it would take 2-3 weeks to arrive (because they wanted to just put it in their next container that was due to come over), I contacted yearone.com, valve = $76, postage in 3-5 days = $36, plus taxes = $133 bargain! [ April 17, 2003: Message edited by: andybird ]</strong><hr></blockquote> I get mine at Pick-A-Part for $5!! |
