Pine Tree Sap/Pitch - use solvent or buff?
I realize this question must have been asked a million times here. However I did not see it in the FAQ.
I recently acquired an '89 Cougar that is in excellent condition except it was parked near pine trees and has quite a bit of sap/pine pitch on the paint. Is it best to use a solvent approach, such as bug/tar remover or kerosene? Or better to buff off with a mild compound? The paint is factory - whatever they were using back then. And the color is white. Thanks! -- Ken |
Thanks - good replies. I will try the dawn and reducer for sure. I didn't think about the sap clogging up the pad - but that makes sense. I'll let u guys know what happens.
Paint thinner (basically bug and tar remover at a fraction of the price) is a great on tree sap (they share the same chemistry!) and is very gentle on car paint.
I have to suggest using a clay bar. Pick up a clay bar kit and follow the instructions. You will be amazed by the results. You will have to re-wax after any of the above cleanings so pick up a good carnuba wax while you're at it...
Mark |
I have used WD-40 in the past with good results.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
Use enamel thinner (mineral spirits). Lacquer thinner will take off flesh so don't uuse it!!!
I ended up hand-rubbing the paint with Meguiars's #4. It worked great - there was a ton of crap on this paint!
Thanks again for all the input. I think next time I will try the grated cheese...! |
| kingpins | dusterbd | Suspension - Brakes - Steering | 5 | 08-14-2003 04:44 AM |
