Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinging on 03 Chevy 5.3 Engine in Suburban
Old 07-30-2009, 08:28 AM
bry21317 bry21317 is offline
Ok Guys. Sorry about this.
I am not sure if this information will tell you the altitude or not. I am located in Raleigh, NC and we are located at 434 Feet above Sea Level, by Google. As to what the car is set to, I do not know. I have the Acront Elite Autoscanner CP9185.
As to how long it takes to start the car, its only a turn of the key, starts right up. no problems there ever. I would say max 1.5 seconds.
Here is the Information, for the 29 Frames it Recorded on the way into to work today, it only does it for about 30 secs, and this was normal driving. I tried to make it ping, as it normally will do it around 2000k, when in the throttle, but I was not able to make it happen. So not sure if this will work good or not. Also ambient air temp was 84 and low humidity. This afternoon it will be around 90 and very humid. So it should do it then for sure.
I know this data is very long, but if you wish I can put it into a .txt file, so the post is not near as long. Tell me if there are any other specific items you want me to look at on the scanner, as I do not think its recording all of them on here, when its connected to the computer.
Thanks,
Bryan
Playback Data
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 604
CALC LOAD(%) 3.1
MAF(LB/M) 1.10
MAP("HG) 13.9
COOLANT(øF) 199
IAT(øF) 91
IGN ADV(DEG) 17.0
ST FTRM1(%) -1.6
LT FTRM1(%) -0.8
ST FTRM2(%) -1.6
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.100
ST FTRM11(%) -0.8
O2S12(V) 0.645
O2S21(V) 0.175
ST FTRM21(%) 0.0
O2S22(V) 0.525
PTO STATUS Disen
OBD2 STAT CA
FRAME: -5 TM: -15.9
MIL STATUS Off
ABSLT TPS(%) 10.2
ENGINE SPD(RPM) 603
CALC LOAD(%) 3.1
MAF(LB/M) 1.10
MAP("HG) 13.9
COOLANT(øF) 199
IAT(øF) 91
IGN ADV(DEG) 17.0
ST FTRM1(%) -0.8
LT FTRM1(%) -0.8
ST FTRM2(%) 0.0
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.700
ST FTRM11(%) -1.6
O2S12(V) 0.710
O2S21(V) 0.795
ST FTRM21(%) -2.3
O2S22(V) 0.655
PTO STATUS Disen
OBD2 STAT CA
FRAME: -4 TM: -12.7
MIL STATUS Off
ABSLT TPS(%) 10.2
ENGINE SPD(RPM) 602
CALC LOAD(%) 3.1
MAF(LB/M) 1.10
MAP("HG) 13.9
COOLANT(øF) 201
IAT(øF) 91
IGN ADV(DEG) 17.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
ST FTRM2(%) 0.0
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.650
ST FTRM11(%) -1.6
O2S12(V) 0.730
O2S21(V) 0.805
ST FTRM21(%) -0.8
O2S22(V) 0.640
PTO STATUS Disen
OBD2 STAT CA
FRAME: -3 TM: -9.5
MIL STATUS Off
ABSLT TPS(%) 10.2
ENGINE SPD(RPM) 612
CALC LOAD(%) 3.1
MAF(LB/M) 1.10
MAP("HG) 13.9
COOLANT(øF) 201
IAT(øF) 91
IGN ADV(DEG) 15.0
ST FTRM1(%) 1.6
LT FTRM1(%) -0.8
ST FTRM2(%) 2.3
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.075
ST FTRM11(%) 2.3
O2S12(V) 0.510
O2S21(V) 0.735
ST FTRM21(%) 2.3
O2S22(V) 0.425
PTO STATUS Disen
OBD2 STAT CA
FRAME: -2 TM: -6.3
MIL STATUS Off
ABSLT TPS(%) 10.2
ENGINE SPD(RPM) 600
CALC LOAD(%) 3.1
MAF(LB/M) 1.09
MAP("HG) 13.6
COOLANT(øF) 201
IAT(øF) 91
IGN ADV(DEG) 17.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
ST FTRM2(%) 0.0
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.185
ST FTRM11(%) 0.8
O2S12(V) 0.725
O2S21(V) 0.805
ST FTRM21(%) 0.0
O2S22(V) 0.700
PTO STATUS Disen
OBD2 STAT CA
FRAME: -1 TM: -3.2
MIL STATUS Off
ABSLT TPS(%) 10.2
ENGINE SPD(RPM) 608
CALC LOAD(%) 3.1
MAF(LB/M) 1.09
MAP("HG) 13.9
COOLANT(øF) 201
IAT(øF) 91
IGN ADV(DEG) 16.5
ST FTRM1(%) -0.8
LT FTRM1(%) -0.8
ST FTRM2(%) 0.0
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.805
ST FTRM11(%) -0.8
O2S12(V) 0.795
O2S21(V) 0.665
ST FTRM21(%) -0.8
O2S22(V) 0.750
PTO STATUS Disen
OBD2 STAT CA
FRAME: 0 TM: 0.0
MIL STATUS Off
ABSLT TPS(%) 10.2
ENGINE SPD(RPM) 604
CALC LOAD(%) 3.1
MAF(LB/M) 1.10
MAP("HG) 13.9
COOLANT(øF) 201
IAT(øF) 93
IGN ADV(DEG) 17.5
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
ST FTRM2(%) -1.6
LT FTRM2(%) 2.3
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.845
ST FTRM11(%) -4.7
O2S12(V) 0.835
O2S21(V) 0.670
ST FTRM21(%) 1.6
O2S22(V) 0.105
PTO STATUS Disen
OBD2 STAT CA
FRAME: 1 TM: 3.4
MIL STATUS Off
ABSLT TPS(%) 65.9
ENGINE SPD(RPM)2043
CALC LOAD(%) 31.4
MAF(LB/M) 10.70
MAP("HG) 29.2
COOLANT(øF) 201
IAT(øF) 93
IGN ADV(DEG) 24.5
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 22
FUEL SYS1 OPEN1
FUEL SYS2 OPEN1
O2S11(V) 0.890
ST FTRM11(%) 0.0
O2S12(V) 0.900
O2S21(V) 0.915
ST FTRM21(%) 0.0
O2S22(V) 0.880
PTO STATUS Disen
OBD2 STAT CA
FRAME: 2 TM: 6.6
MIL STATUS Off
ABSLT TPS(%) 85.1
ENGINE SPD(RPM)4485
CALC LOAD(%) 80.0
MAF(LB/M) 27.42
MAP("HG) 28.3
COOLANT(øF) 201
IAT(øF) 93
IGN ADV(DEG) 28.5
ST FTRM1(%) -6.3
LT FTRM1(%) 0.0
ST FTRM2(%) -8.6
LT FTRM2(%) 0.0
VEH SPEED(MPH) 41
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.075
ST FTRM11(%) -1.6
O2S12(V) 0.205
O2S21(V) 0.165
ST FTRM21(%) -7.0
O2S22(V) 0.415
PTO STATUS Disen
OBD2 STAT CA
FRAME: 3 TM: 9.8
MIL STATUS Off
ABSLT TPS(%) 26.7
ENGINE SPD(RPM)1895
CALC LOAD(%) 15.3
MAF(LB/M) 5.14
MAP("HG) 17.1
COOLANT(øF) 199
IAT(øF) 95
IGN ADV(DEG) 29.0
ST FTRM1(%) 1.6
LT FTRM1(%) -0.8
ST FTRM2(%) -1.6
LT FTRM2(%) 0.0
VEH SPEED(MPH) 42
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.745
ST FTRM11(%) -0.8
O2S12(V) 0.820
O2S21(V) 0.285
ST FTRM21(%) 3.9
O2S22(V) 0.850
PTO STATUS Disen
OBD2 STAT CA
FRAME: 4 TM: 13.0
MIL STATUS Off
ABSLT TPS(%) 23.5
ENGINE SPD(RPM)1873
CALC LOAD(%) 39.2
MAF(LB/M) 10.22
MAP("HG) 24.8
COOLANT(øF) 199
IAT(øF) 95
IGN ADV(DEG) 38.0
ST FTRM1(%) 2.3
LT FTRM1(%) -1.6
ST FTRM2(%) 3.9
LT FTRM2(%) 0.0
VEH SPEED(MPH) 43
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.815
ST FTRM11(%) 0.8
O2S12(V) 0.515
O2S21(V) 0.125
ST FTRM21(%) 6.3
O2S22(V) 0.480
PTO STATUS Disen
OBD2 STAT CA
FRAME: 5 TM: 16.2
MIL STATUS Off
ABSLT TPS(%) 24.7
ENGINE SPD(RPM)1942
CALC LOAD(%) 8.2
MAF(LB/M) 2.55
MAP("HG) 10.3
COOLANT(øF) 199
IAT(øF) 93
IGN ADV(DEG) 46.5
ST FTRM1(%) -1.6
LT FTRM1(%) -2.3
ST FTRM2(%) -3.1
LT FTRM2(%) -0.8
VEH SPEED(MPH) 45
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.770
ST FTRM11(%) -3.1
O2S12(V) 0.805
O2S21(V) 0.430
ST FTRM21(%) 1.6
O2S22(V) 0.735
PTO STATUS Disen
OBD2 STAT CA
FRAME: 6 TM: 19.4
MIL STATUS Off
ABSLT TPS(%) 19.2
ENGINE SPD(RPM)1798
CALC LOAD(%) 9.4
MAF(LB/M) 3.14
MAP("HG) 10.9
COOLANT(øF) 199
IAT(øF) 93
IGN ADV(DEG) 38.5
ST FTRM1(%) -2.3
LT FTRM1(%) -1.6
ST FTRM2(%) 2.3
LT FTRM2(%) -0.8
VEH SPEED(MPH) 45
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.075
ST FTRM11(%) 0.8
O2S12(V) 0.250
O2S21(V) 0.130
ST FTRM21(%) 4.7
O2S22(V) 0.645
PTO STATUS Disen
OBD2 STAT CA
FRAME: 7 TM: 22.6
MIL STATUS Off
ABSLT TPS(%) 25.1
ENGINE SPD(RPM)1997
CALC LOAD(%) 14.1
MAF(LB/M) 4.68
MAP("HG) 14.8
COOLANT(øF) 199
IAT(øF) 93
IGN ADV(DEG) 39.5
ST FTRM1(%) 0.0
LT FTRM1(%) -1.6
ST FTRM2(%) -0.8
LT FTRM2(%) -0.8
VEH SPEED(MPH) 47
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.155
ST FTRM11(%) 2.3
O2S12(V) 0.690
O2S21(V) 0.840
ST FTRM21(%) -2.3
O2S22(V) 0.800
PTO STATUS Disen
OBD2 STAT CA
FRAME: 8 TM: 25.7
MIL STATUS Off
ABSLT TPS(%) 23.5
ENGINE SPD(RPM)1471
CALC LOAD(%) 12.2
MAF(LB/M) 4.10
MAP("HG) 17.1
COOLANT(øF) 199
IAT(øF) 93
IGN ADV(DEG) 30.5
ST FTRM1(%) 3.1
LT FTRM1(%) -0.8
ST FTRM2(%) 1.6
LT FTRM2(%) 0.0
VEH SPEED(MPH) 48
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.735
ST FTRM11(%) 0.0
O2S12(V) 0.785
O2S21(V) 0.795
ST FTRM21(%) -3.1
O2S22(V) 0.760
PTO STATUS Disen
OBD2 STAT CA
FRAME: 9 TM: 28.9
MIL STATUS Off
ABSLT TPS(%) 22.4
ENGINE SPD(RPM)1458
CALC LOAD(%) 11.4
MAF(LB/M) 3.73
MAP("HG) 15.9
COOLANT(øF) 199
IAT(øF) 93
IGN ADV(DEG) 33.0
ST FTRM1(%) -0.8
LT FTRM1(%) -1.6
ST FTRM2(%) 3.1
LT FTRM2(%) -0.8
VEH SPEED(MPH) 48
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.805
ST FTRM11(%) -0.8
O2S12(V) 0.800
O2S21(V) 0.820
ST FTRM21(%) -1.6
O2S22(V) 0.775
PTO STATUS Disen
OBD2 STAT CA
FRAME: 10 TM: 32.1
MIL STATUS Off
ABSLT TPS(%) 17.6
ENGINE SPD(RPM)1438
CALC LOAD(%) 6.7
MAF(LB/M) 2.05
MAP("HG) 10.3
COOLANT(øF) 199
IAT(øF) 93
IGN ADV(DEG) 35.0
ST FTRM1(%) 3.1
LT FTRM1(%) -2.3
ST FTRM2(%) -1.6
LT FTRM2(%) -0.8
VEH SPEED(MPH) 47
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.755
ST FTRM11(%) -3.1
O2S12(V) 0.735
O2S21(V) 0.805
ST FTRM21(%) -0.8
O2S22(V) 0.705
PTO STATUS Disen
OBD2 STAT CA
FRAME: 11 TM: 35.3
MIL STATUS Off
ABSLT TPS(%) 14.5
ENGINE SPD(RPM)1361
CALC LOAD(%) 4.7
MAF(LB/M) 1.64
MAP("HG) 8.9
COOLANT(øF) 198
IAT(øF) 93
IGN ADV(DEG) 34.5
ST FTRM1(%) 0.0
LT FTRM1(%) -2.3
ST FTRM2(%) -0.8
LT FTRM2(%) -0.8
VEH SPEED(MPH) 46
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.770
ST FTRM11(%) 4.7
O2S12(V) 0.790
O2S21(V) 0.245
ST FTRM21(%) 4.7
O2S22(V) 0.735
PTO STATUS Disen
OBD2 STAT CA
FRAME: 12 TM: 38.5
MIL STATUS Off
ABSLT TPS(%) 14.1
ENGINE SPD(RPM)1338
CALC LOAD(%) 4.7
MAF(LB/M) 1.69
MAP("HG) 9.2
COOLANT(øF) 198
IAT(øF) 93
IGN ADV(DEG) 33.0
ST FTRM1(%) 1.6
LT FTRM1(%) -2.3
ST FTRM2(%) 3.9
LT FTRM2(%) -0.8
VEH SPEED(MPH) 45
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.715
ST FTRM11(%) -2.3
O2S12(V) 0.750
O2S21(V) 0.815
ST FTRM21(%) -1.6
O2S22(V) 0.735
PTO STATUS Disen
OBD2 STAT CA
FRAME: 13 TM: 41.7
MIL STATUS Off
ABSLT TPS(%) 14.9
ENGINE SPD(RPM)1316
CALC LOAD(%) 5.1
MAF(LB/M) 1.76
MAP("HG) 9.4
COOLANT(øF) 198
IAT(øF) 93
IGN ADV(DEG) 38.5
ST FTRM1(%) 4.7
LT FTRM1(%) -1.6
ST FTRM2(%) -1.6
LT FTRM2(%) -0.8
VEH SPEED(MPH) 44
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.765
ST FTRM11(%) -2.3
O2S12(V) 0.775
O2S21(V) 0.315
ST FTRM21(%) 4.7
O2S22(V) 0.730
PTO STATUS Disen
OBD2 STAT CA
FRAME: 14 TM: 44.9
MIL STATUS Off
ABSLT TPS(%) 15.7
ENGINE SPD(RPM)1299
CALC LOAD(%) 6.3
MAF(LB/M) 2.08
MAP("HG) 10.9
COOLANT(øF) 198
IAT(øF) 93
IGN ADV(DEG) 38.5
ST FTRM1(%) 3.9
LT FTRM1(%) -2.3
ST FTRM2(%) 7.0
LT FTRM2(%) -1.6
VEH SPEED(MPH) 43
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.755
ST FTRM11(%) 0.0
O2S12(V) 0.370
O2S21(V) 0.805
ST FTRM21(%) 0.0
O2S22(V) 0.690
PTO STATUS Disen
OBD2 STAT CA
FRAME: 15 TM: 48.1
MIL STATUS Off
ABSLT TPS(%) 13.7
ENGINE SPD(RPM)1271
CALC LOAD(%) 4.7
MAF(LB/M) 1.61
MAP("HG) 9.2
COOLANT(øF) 198
IAT(øF) 93
IGN ADV(DEG) 36.5
ST FTRM1(%) 5.5
LT FTRM1(%) -2.3
ST FTRM2(%) 0.8
LT FTRM2(%) -0.8
VEH SPEED(MPH) 42
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.125
ST FTRM11(%) 6.3
O2S12(V) 0.810
O2S21(V) 0.790
ST FTRM21(%) -3.1
O2S22(V) 0.710
PTO STATUS Disen
OBD2 STAT CA
FRAME: 16 TM: 51.3
MIL STATUS Off
ABSLT TPS(%) 21.2
ENGINE SPD(RPM)1267
CALC LOAD(%) 11.0
MAF(LB/M) 3.52
MAP("HG) 16.5
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 30.5
ST FTRM1(%) 3.9
LT FTRM1(%) -2.3
ST FTRM2(%) -0.8
LT FTRM2(%) -0.8
VEH SPEED(MPH) 43
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.760
ST FTRM11(%) 5.5
O2S12(V) 0.700
O2S21(V) 0.125
ST FTRM21(%) 6.3
O2S22(V) 0.700
PTO STATUS Disen
OBD2 STAT CA
FRAME: 17 TM: 54.5
MIL STATUS Off
ABSLT TPS(%) 19.6
ENGINE SPD(RPM)1310
CALC LOAD(%) 8.2
MAF(LB/M) 2.68
MAP("HG) 13.9
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 32.5
ST FTRM1(%) 0.0
LT FTRM1(%) -2.3
ST FTRM2(%) -1.6
LT FTRM2(%) -0.8
VEH SPEED(MPH) 42
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.375
ST FTRM11(%) 3.9
O2S12(V) 0.730
O2S21(V) 0.175
ST FTRM21(%) -1.6
O2S22(V) 0.745
PTO STATUS Disen
OBD2 STAT CA
FRAME: 18 TM: 57.7
MIL STATUS Off
ABSLT TPS(%) 15.3
ENGINE SPD(RPM)1248
CALC LOAD(%) 5.5
MAF(LB/M) 1.73
MAP("HG) 10.3
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 28.0
ST FTRM1(%) 6.3
LT FTRM1(%) -2.3
ST FTRM2(%) 9.4
LT FTRM2(%) -0.8
VEH SPEED(MPH) 40
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.375
ST FTRM11(%) 1.6
O2S12(V) 0.275
O2S21(V) 0.265
ST FTRM21(%) 7.8
O2S22(V) 0.625
PTO STATUS Disen
OBD2 STAT CA
FRAME: 19 TM: 60.9
MIL STATUS Off
ABSLT TPS(%) 13.3
ENGINE SPD(RPM)1159
CALC LOAD(%) 4.7
MAF(LB/M) 1.55
MAP("HG) 9.7
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 25.5
ST FTRM1(%) 5.5
LT FTRM1(%) -2.3
ST FTRM2(%) -0.8
LT FTRM2(%) 0.0
VEH SPEED(MPH) 35
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.085
ST FTRM11(%) 4.7
O2S12(V) 0.770
O2S21(V) 0.600
ST FTRM21(%) 4.7
O2S22(V) 0.760
PTO STATUS Disen
OBD2 STAT CA
FRAME: 20
MIL STATUS Off
ABSLT TPS(%) 12.5
ENGINE SPD(RPM) 850
CALC LOAD(%) 3.9
MAF(LB/M) 1.36
MAP("HG) 11.8
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 18.0
ST FTRM1(%) -6.3
LT FTRM1(%) -0.8
ST FTRM2(%) -6.3
LT FTRM2(%) 2.3
VEH SPEED(MPH) 20
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.810
ST FTRM11(%) -5.5
O2S12(V) 0.805
O2S21(V) 0.705
ST FTRM21(%) -0.8
O2S22(V) 0.750
PTO STATUS Disen
OBD2 STAT CA
FRAME: 21 TM: 67.3
MIL STATUS Off
ABSLT TPS(%) 12.9
ENGINE SPD(RPM) 783
CALC LOAD(%) 3.9
MAF(LB/M) 1.38
MAP("HG) 13.0
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 18.0
ST FTRM1(%) -7.0
LT FTRM1(%) -2.3
ST FTRM2(%) -7.8
LT FTRM2(%) 0.0
VEH SPEED(MPH) 6
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.775
ST FTRM11(%) -0.8
O2S12(V) 0.735
O2S21(V) 0.125
ST FTRM21(%) 0.8
O2S22(V) 0.685
PTO STATUS Disen
OBD2 STAT CA
FRAME: 22 TM: 70.5
MIL STATUS Off
ABSLT TPS(%) 10.2
ENGINE SPD(RPM) 604
CALC LOAD(%) 3.1
MAF(LB/M) 1.10
MAP("HG) 13.6
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 16.5
ST FTRM1(%) -3.1
LT FTRM1(%) -0.8
ST FTRM2(%) -1.6
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.750
ST FTRM11(%) -2.3
O2S12(V) 0.785
O2S21(V) 0.160
ST FTRM21(%) 0.0
O2S22(V) 0.755
PTO STATUS Disen
OBD2 STAT CA
FRAME: 23 TM: 73.7
MIL STATUS Off
ABSLT TPS(%) 9.8
ENGINE SPD(RPM) 600
CALC LOAD(%) 3.1
MAF(LB/M) 1.07
MAP("HG) 13.6
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 17.5
ST FTRM1(%) -2.3
LT FTRM1(%) -0.8
ST FTRM2(%) -2.3
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.305
ST FTRM11(%) -0.8
O2S12(V) 0.790
O2S21(V) 0.175
ST FTRM21(%) -0.8
O2S22(V) 0.710
PTO STATUS Disen
OBD2 STAT CA
FRAME: 24 TM: 76.9
MIL STATUS Off
ABSLT TPS(%) 9.8
ENGINE SPD(RPM) 592
CALC LOAD(%) 3.1
MAF(LB/M) 1.08
MAP("HG) 13.6
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 18.0
ST FTRM1(%) -1.6
LT FTRM1(%) -0.8
ST FTRM2(%) -0.8
LT FTRM2(%) -0.8
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.670
ST FTRM11(%) 0.0
O2S12(V) 0.790
O2S21(V) 0.795
ST FTRM21(%) -2.3
O2S22(V) 0.685
PTO STATUS Disen
OBD2 STAT CA
FRAME: 25 TM: 80.1
MIL STATUS Off
ABSLT TPS(%) 23.9
ENGINE SPD(RPM)1149
CALC LOAD(%) 12.2
MAF(LB/M) 4.15
MAP("HG) 20.4
COOLANT(øF) 196
IAT(øF) 93
IGN ADV(DEG) 25.0
ST FTRM1(%) -0.8
LT FTRM1(%) 0.0
ST FTRM2(%) 3.1
LT FTRM2(%) 2.3
VEH SPEED(MPH) 8
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.790
ST FTRM11(%) 3.1
O2S12(V) 0.505
O2S21(V) 0.130
ST FTRM21(%) -2.3
O2S22(V) 0.790
PTO STATUS Disen
OBD2 STAT CA
FRAME: 26 TM: 83.3
MIL STATUS Off
ABSLT TPS(%) 36.9
ENGINE SPD(RPM)2170
CALC LOAD(%) 32.2
MAF(LB/M) 12.24
MAP("HG) 27.8
COOLANT(øF) 198
IAT(øF) 93
IGN ADV(DEG) 28.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
ST FTRM2(%) 6.3
LT FTRM2(%) 0.0
VEH SPEED(MPH) 24
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.515
ST FTRM11(%) -0.8
O2S12(V) 0.835
O2S21(V) 0.885
ST FTRM21(%) -3.1
O2S22(V) 0.885
PTO STATUS Disen
OBD2 STAT CA
FRAME: 27 TM: 86.5
MIL STATUS Off
ABSLT TPS(%) 14.1
ENGINE SPD(RPM)1886
CALC LOAD(%) 4.7
MAF(LB/M) 1.53
MAP("HG) 6.8
COOLANT(øF) 198
IAT(øF) 93
IGN ADV(DEG) 39.5
ST FTRM1(%) 0.0
LT FTRM1(%) -3.9
ST FTRM2(%) 3.1
LT FTRM2(%) 0.0
VEH SPEED(MPH) 29
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.100
ST FTRM11(%) 7.0
O2S12(V) 0.165
O2S21(V) 0.805
ST FTRM21(%) -0.8
O2S22(V) 0.830
PTO STATUS Disen
OBD2 STAT CA
FRAME: 28 TM: 89.6
MIL STATUS Off
ABSLT TPS(%) 23.5
ENGINE SPD(RPM)1380
CALC LOAD(%) 11.8
MAF(LB/M) 3.91
MAP("HG) 18.0
COOLANT(øF) 196
IAT(øF) 95
IGN ADV(DEG) 29.0
ST FTRM1(%) 3.1
LT FTRM1(%) 0.0
ST FTRM2(%) -4.7
LT FTRM2(%) 2.3
VEH SPEED(MPH) 30
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.085
ST FTRM11(%) 2.3
O2S12(V) 0.765
O2S21(V) 0.175
ST FTRM21(%) 2.3
O2S22(V) 0.790
PTO ST
