Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinging on 03 Chevy 5.3 Engine in Suburban
Old 07-30-2009, 11:23 AM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
I am at 565 feet above sea level. Most of the MAP HG's I've checked have been around 28.6 at idle. Within 30 miles I can be at 3200 feet. I use this drive to test the MAP sensor at a steady throttle. It should be down around 25.5 HG at this height.
I noticed that your MAP HG was down between 9 and 12.5 with your throttle open percentage around 10-12 %, and the engine RPM between 600 and 900.
It only increased to over 28 HG. When you were on the throttle.
ABSLT TPS(%) 65.9
ENGINE SPD(RPM)2043
CALC LOAD(%) 31.4
MAF(LB/M) 10.70
MAP("HG) 29.2
This makes me think it is hooked to a ported vacuum source, wired wrong, or out of range. 9 to 12 HG readings should be somewhere between 6000 to 8500 feet above sea level.
