Pinging on 03 Chevy 5.3 Engine in Suburban - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-31-2009, 08:12 AM
Ok,
So the 29.5 HG was with the Engine off, Key on. I got another Recording this morning, a lil longer, but the IAT seems to be way low compared to what it was doing yesterday when it was so Hot outside. It was not pinging at all, but the O2 Readings look to still be high.
this was the First Drive with the new MAP Sensor installed. I still can not find the EGR Spindle you were referring to. I looked everywhere, but crawling up under the car and looking up on the back of the block. I am not able to see any wires anywhere, on the heads that are not running to the Injectors or the coils.
Bryan
2003 K-Series
Z=5.3L
Auto 4 Speed
With Throttle Ctrl
< 8600 GVW
2 Speed ATC
Playback Data
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 601
CALC LOAD(%) 3.1
MAF(LB/M) 1.13
MAP("HG) 14.2
COOLANT(F) 205
IAT(F) 93
IGN ADV(DEG) 16.5
ST FTRM1(%) -3.1
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.080
ST FTRM11(%) -1.6
O2S12(V) 0.670
O2S21(V) 0.615
ST FTRM21(%) -0.8
O2S22(V) 0.655
PTO STATUS Disen
OBD2 STAT CA
FRAME: -5 TM: -15.9
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 599
CALC LOAD(%) 3.1
MAF(LB/M) 1.13
MAP("HG) 14.2
COOLANT(F) 205
IAT(F) 93
IGN ADV(DEG) 17.5
ST FTRM1(%) -2.3
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.140
ST FTRM11(%) -0.8
O2S12(V) 0.725
O2S21(V) 0.795
ST FTRM21(%) -1.6
O2S22(V) 0.615
PTO STATUS Disen
OBD2 STAT CA
FRAME: -4 TM: -12.8
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 599
CALC LOAD(%) 3.1
MAF(LB/M) 1.13
MAP("HG) 14.2
COOLANT(F) 205
IAT(F) 95
IGN ADV(DEG) 17.0
ST FTRM1(%) -3.9
LT FTRM1(%) 0.0
ST FTRM2(%) -1.6
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.100
ST FTRM11(%) -0.8
O2S12(V) 0.640
O2S21(V) 0.790
ST FTRM21(%) -1.6
O2S22(V) 0.670
PTO STATUS Disen
OBD2 STAT CA
FRAME: -3 TM: -9.6
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 600
CALC LOAD(%) 3.1
MAF(LB/M) 1.13
MAP("HG) 14.2
COOLANT(F) 205
IAT(F) 95
IGN ADV(DEG) 17.0
ST FTRM1(%) -3.1
LT FTRM1(%) 0.0
ST FTRM2(%) -0.8
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.115
ST FTRM11(%) -0.8
O2S12(V) 0.420
O2S21(V) 0.315
ST FTRM21(%) 0.0
O2S22(V) 0.725
PTO STATUS Disen
OBD2 STAT CA
FRAME: -2 TM: -6.4
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 596
CALC LOAD(%) 3.1
MAF(LB/M) 1.13
MAP("HG) 14.2
COOLANT(F) 205
IAT(F) 95
IGN ADV(DEG) 17.0
ST FTRM1(%) -2.3
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.695
ST FTRM11(%) -0.8
O2S12(V) 0.735
O2S21(V) 0.310
ST FTRM21(%) 0.0
O2S22(V) 0.700
PTO STATUS Disen
OBD2 STAT CA
FRAME: -1 TM: -3.2
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 592
CALC LOAD(%) 3.1
MAF(LB/M) 1.12
MAP("HG) 14.2
COOLANT(F) 205
IAT(F) 95
IGN ADV(DEG) 18.0
ST FTRM1(%) -0.8
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.655
ST FTRM11(%) -2.3
O2S12(V) 0.725
O2S21(V) 0.200
ST FTRM21(%) 0.0
O2S22(V) 0.670
PTO STATUS Disen
OBD2 STAT CA
FRAME: 0 TM: 0.0
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 594
CALC LOAD(%) 3.1
MAF(LB/M) 1.13
MAP("HG) 14.2
COOLANT(F) 205
IAT(F) 95
IGN ADV(DEG) 17.0
ST FTRM1(%) 0.0
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.135
ST FTRM11(%) 0.0
O2S12(V) 0.715
O2S21(V) 0.805
ST FTRM21(%) -1.6
O2S22(V) 0.700
PTO STATUS Disen
OBD2 STAT CA
FRAME: 1 TM: 3.3
MIL STATUS Off
ABSLT TPS(%) 10.6
ENGINE SPD(RPM) 598
CALC LOAD(%) 3.1
MAF(LB/M) 1.12
MAP("HG) 14.2
COOLANT(F) 205
IAT(F) 95
IGN ADV(DEG) 17.5
ST FTRM1(%) -2.3
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.130
ST FTRM11(%) -0.8
O2S12(V) 0.715
O2S21(V) 0.350
ST FTRM21(%) 2.3
O2S22(V) 0.540
PTO STATUS Disen
OBD2 STAT CA
FRAME: 2 TM: 6.5
MIL STATUS Off
ABSLT TPS(%) 31.4
ENGINE SPD(RPM)1432
CALC LOAD(%) 20.4
MAF(LB/M) 7.36
MAP("HG) 26.3
COOLANT(F) 205
IAT(F) 95
IGN ADV(DEG) 21.5
ST FTRM1(%) -3.1
LT FTRM1(%) 0.8
ST FTRM2(%) -2.3
LT FTRM2(%) 1.6
VEH SPEED(MPH) 15
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.775
ST FTRM11(%) 3.1
O2S12(V) 0.785
O2S21(V) 0.440
ST FTRM21(%) -3.1
O2S22(V) 0.680
PTO STATUS Disen
OBD2 STAT CA
FRAME: 3 TM: 9.7
MIL STATUS Off
ABSLT TPS(%) 72.9
ENGINE SPD(RPM)3434
CALC LOAD(%) 58.4
MAF(LB/M) 19.50
MAP("HG) 28.6
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 28.0
ST FTRM1(%) 0.0
LT FTRM1(%) 2.3
ST FTRM2(%) 0.0
LT FTRM2(%) 2.3
VEH SPEED(MPH) 35
FUEL SYS1 OPEN1
FUEL SYS2 OPEN1
O2S11(V) 0.890
ST FTRM11(%) 0.0
O2S12(V) 0.910
O2S21(V) 0.925
ST FTRM21(%) 0.0
O2S22(V) 0.905
PTO STATUS Disen
OBD2 STAT CA
FRAME: 4 TM: 12.9
MIL STATUS Off
ABSLT TPS(%) 86.3
ENGINE SPD(RPM)3089
CALC LOAD(%) 49.4
MAF(LB/M) 16.34
MAP("HG) 28.9
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 28.0
ST FTRM1(%) 0.0
LT FTRM1(%) 2.3
ST FTRM2(%) 0.0
LT FTRM2(%) 2.3
VEH SPEED(MPH) 48
FUEL SYS1 OPEN1
FUEL SYS2 OPEN1
O2S11(V) 0.890
ST FTRM11(%) 0.0
O2S12(V) 0.910
O2S21(V) 0.925
ST FTRM21(%) -7.0
O2S22(V) 0.835
PTO STATUS Disen
OBD2 STAT CA
FRAME: 5 TM: 16.1
MIL STATUS Off
ABSLT TPS(%) 58.0
ENGINE SPD(RPM)3692
CALC LOAD(%) 54.1
MAF(LB/M) 13.12
MAP("HG) 26.0
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 23.5
ST FTRM1(%) -1.6
LT FTRM1(%) 1.6
ST FTRM2(%) -5.5
LT FTRM2(%) 2.3
VEH SPEED(MPH) 54
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.210
ST FTRM11(%) -7.8
O2S12(V) 0.835
O2S21(V) 0.735
ST FTRM21(%) -3.9
O2S22(V) 0.715
PTO STATUS Disen
OBD2 STAT CA
FRAME: 6 TM: 19.3
MIL STATUS Off
ABSLT TPS(%) 17.6
ENGINE SPD(RPM)1573
CALC LOAD(%) 6.3
MAF(LB/M) 2.10
MAP("HG) 9.4
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 41.0
ST FTRM1(%) 1.6
LT FTRM1(%) -2.3
ST FTRM2(%) 1.6
LT FTRM2(%) -1.6
VEH SPEED(MPH) 50
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.785
ST FTRM11(%) -2.3
O2S12(V) 0.520
O2S21(V) 0.130
ST FTRM21(%) 3.1
O2S22(V) 0.355
PTO STATUS Disen
OBD2 STAT CA
FRAME: 7 TM: 22.5
MIL STATUS Off
ABSLT TPS(%) 14.5
ENGINE SPD(RPM)1349
CALC LOAD(%) 5.1
MAF(LB/M) 1.71
MAP("HG) 9.4
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 30.5
ST FTRM1(%) -2.3
LT FTRM1(%) 0.0
ST FTRM2(%) -3.1
LT FTRM2(%) 2.3
VEH SPEED(MPH) 40
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.740
ST FTRM11(%) -5.5
O2S12(V) 0.790
O2S21(V) 0.790
ST FTRM21(%) -4.7
O2S22(V) 0.765
PTO STATUS Disen
OBD2 STAT CA
FRAME: 8 TM: 25.7
MIL STATUS Off
ABSLT TPS(%) 13.3
ENGINE SPD(RPM)1053
CALC LOAD(%) 4.7
MAF(LB/M) 1.55
MAP("HG) 10.9
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 21.5
ST FTRM1(%) -4.7
LT FTRM1(%) -3.9
ST FTRM2(%) 1.6
LT FTRM2(%) -0.8
VEH SPEED(MPH) 29
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.730
ST FTRM11(%) 0.0
O2S12(V) 0.710
O2S21(V) 0.130
ST FTRM21(%) 0.0
O2S22(V) 0.680
PTO STATUS Disen
OBD2 STAT CA
FRAME: 9 TM: 28.9
MIL STATUS Off
ABSLT TPS(%) 12.2
ENGINE SPD(RPM) 722
CALC LOAD(%) 3.9
MAF(LB/M) 1.40
MAP("HG) 13.9
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 17.0
ST FTRM1(%) 0.0
LT FTRM1(%) -0.8
ST FTRM2(%) -6.3
LT FTRM2(%) 0.0
VEH SPEED(MPH) 15
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.140
ST FTRM11(%) 0.0
O2S12(V) 0.745
O2S21(V) 0.810
ST FTRM21(%) -5.5
O2S22(V) 0.705
PTO STATUS Disen
OBD2 STAT CA
FRAME: 10 TM: 32.1
MIL STATUS Off
ABSLT TPS(%) 26.3
ENGINE SPD(RPM)1415
CALC LOAD(%) 14.1
MAF(LB/M) 4.64
MAP("HG) 20.1
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 25.0
ST FTRM1(%) 3.1
LT FTRM1(%) 0.0
ST FTRM2(%) -2.3
LT FTRM2(%) -0.8
VEH SPEED(MPH) 17
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.200
ST FTRM11(%) 3.1
O2S12(V) 0.765
O2S21(V) 0.820
ST FTRM21(%) -2.3
O2S22(V) 0.750
PTO STATUS Disen
OBD2 STAT CA
FRAME: 11 TM: 35.3
MIL STATUS Off
ABSLT TPS(%) 43.9
ENGINE SPD(RPM)1926
CALC LOAD(%) 28.2
MAF(LB/M) 9.62
MAP("HG) 28.1
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 23.0
ST FTRM1(%) 3.1
LT FTRM1(%) 0.8
ST FTRM2(%) -2.3
LT FTRM2(%) 1.6
VEH SPEED(MPH) 28
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.260
ST FTRM11(%) 2.3
O2S12(V) 0.755
O2S21(V) 0.840
ST FTRM21(%) -2.3
O2S22(V) 0.665
PTO STATUS Disen
OBD2 STAT CA
FRAME: 12 TM: 38.5
MIL STATUS Off
ABSLT TPS(%) 40.4
ENGINE SPD(RPM)2546
CALC LOAD(%) 33.7
MAF(LB/M) 11.11
MAP("HG) 24.2
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 27.5
ST FTRM1(%) 2.3
LT FTRM1(%) 0.8
ST FTRM2(%) -4.7
LT FTRM2(%) 1.6
VEH SPEED(MPH) 39
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.625
ST FTRM11(%) 0.0
O2S12(V) 0.195
O2S21(V) 0.810
ST FTRM21(%) -3.1
O2S22(V) 0.670
PTO STATUS Disen
OBD2 STAT CA
FRAME: 13 TM: 41.7
MIL STATUS Off
ABSLT TPS(%) 18.4
ENGINE SPD(RPM)1716
CALC LOAD(%) 7.1
MAF(LB/M) 2.27
MAP("HG) 10.9
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 27.0
ST FTRM1(%) -5.5
LT FTRM1(%) -3.9
ST FTRM2(%) -3.9
LT FTRM2(%) -0.8
VEH SPEED(MPH) 37
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.125
ST FTRM11(%) 0.0
O2S12(V) 0.730
O2S21(V) 0.805
ST FTRM21(%) -4.7
O2S22(V) 0.735
PTO STATUS Disen
OBD2 STAT CA
FRAME: 14 TM: 44.9
MIL STATUS Off
ABSLT TPS(%) 12.9
ENGINE SPD(RPM) 916
CALC LOAD(%) 4.3
MAF(LB/M) 1.44
MAP("HG) 11.8
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 17.5
ST FTRM1(%) -2.3
LT FTRM1(%) -0.8
ST FTRM2(%) -3.9
LT FTRM2(%) 0.0
VEH SPEED(MPH) 22
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.755
ST FTRM11(%) -3.9
O2S12(V) 0.770
O2S21(V) 0.770
ST FTRM21(%) -6.3
O2S22(V) 0.735
PTO STATUS Disen
OBD2 STAT CA
FRAME: 15 TM: 48.1
MIL STATUS Off
ABSLT TPS(%) 12.5
ENGINE SPD(RPM) 779
CALC LOAD(%) 4.3
MAF(LB/M) 1.51
MAP("HG) 13.3
COOLANT(F) 203
IAT(F) 97
IGN ADV(DEG) 18.5
ST FTRM1(%) -4.7
LT FTRM1(%) -0.8
ST FTRM2(%) 3.1
LT FTRM2(%) 0.0
VEH SPEED(MPH) 18
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.075
ST FTRM11(%) 0.8
O2S12(V) 0.735
O2S21(V) 0.110
ST FTRM21(%) 3.9
O2S22(V) 0.475
PTO STATUS Disen
OBD2 STAT CA
FRAME: 16 TM: 51.3
MIL STATUS Off
ABSLT TPS(%) 19.2
ENGINE SPD(RPM)1063
CALC LOAD(%) 9.4
MAF(LB/M) 3.15
MAP("HG) 17.1
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 27.5
ST FTRM1(%) 6.3
LT FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM2(%) -0.8
VEH SPEED(MPH) 22
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.110
ST FTRM11(%) -1.6
O2S12(V) 0.605
O2S21(V) 0.755
ST FTRM21(%) 6.3
O2S22(V) 0.720
PTO STATUS Disen
OBD2 STAT CA
FRAME: 17 TM: 54.5
MIL STATUS Off
ABSLT TPS(%) 13.7
ENGINE SPD(RPM)1032
CALC LOAD(%) 4.7
MAF(LB/M) 1.54
MAP("HG) 11.2
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 23.0
ST FTRM1(%) 4.7
LT FTRM1(%) -3.9
ST FTRM2(%) 3.9
LT FTRM2(%) 0.0
VEH SPEED(MPH) 24
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.790
ST FTRM11(%) 0.0
O2S12(V) 0.805
O2S21(V) 0.860
ST FTRM21(%) -4.7
O2S22(V) 0.810
PTO STATUS Disen
OBD2 STAT CA
FRAME: 18
MIL STATUS Off
ABSLT TPS(%) 12.2
ENGINE SPD(RPM) 754
CALC LOAD(%) 3.9
MAF(LB/M) 1.36
MAP("HG) 13.3
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 17.0
ST FTRM1(%) 0.8
LT FTRM1(%) -0.8
ST FTRM2(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 19
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.575
ST FTRM11(%) 0.0
O2S12(V) 0.760
O2S21(V) 0.645
ST FTRM21(%) 0.8
O2S22(V) 0.675
PTO STATUS Disen
OBD2 STAT CA
FRAME: 19 TM: 60.8
MIL STATUS Off
ABSLT TPS(%) 12.9
ENGINE SPD(RPM) 775
CALC LOAD(%) 3.9
MAF(LB/M) 1.38
MAP("HG) 13.0
COOLANT(F) 205
IAT(F) 97
IGN ADV(DEG) 17.0
ST FTRM1(%) -2.3
LT FTRM1(%) -0.8
ST FTRM2(%) 5.5
LT FTRM2(%) 0.0
VEH SPEED(MPH) 4
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.105
ST FTRM11(%) -0.8
O2S12(V) 0.725
O2S21(V) 0.820
ST FTRM21(%) 0.0
O2S22(V) 0.760
PTO STATUS Disen
OBD2 STAT CA
FRAME: 20 TM: 64.0
MIL STATUS Off
ABSLT TPS(%) 25.1
ENGINE SPD(RPM)1080
CALC LOAD(%) 13.3
MAF(LB/M) 4.65
MAP("HG) 21.9
COOLANT(F) 203
IAT(F) 97
IGN ADV(DEG) 21.0
ST FTRM1(%) -2.3
LT FTRM1(%) 0.8
ST FTRM2(%) 1.6
LT FTRM2(%) 1.6
VEH SPEED(MPH) 12
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.265
ST FTRM11(%) 3.1
O2S12(V) 0.785
O2S21(V) 0.145
ST FTRM21(%) -2.3
O2S22(V) 0.705
PTO STATUS Disen
OBD2 STAT CA
FRAME: 21 TM: 67.2
MIL STATUS Off
ABSLT TPS(%) 48.2
ENGINE SPD(RPM)2942
CALC LOAD(%) 42.0
MAF(LB/M) 13.02
MAP("HG) 25.1
COOLANT(F) 203
IAT(F) 97
IGN ADV(DEG) 27.0
ST FTRM1(%) -6.3
LT FTRM1(%) 1.6
ST FTRM2(%) -6.3
LT FTRM2(%) 2.3
VEH SPEED(MPH) 28
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.090
ST FTRM11(%) -0.8
O2S12(V) 0.215
O2S21(V) 0.805
ST FTRM21(%) -5.5
O2S22(V) 0.735
PTO STATUS Disen
OBD2 STAT CA
FRAME: 22 TM: 70.4
MIL STATUS Off
ABSLT TPS(%) 16.1
ENGINE SPD(RPM)1325
CALC LOAD(%) 5.5
MAF(LB/M) 1.86
MAP("HG) 10.6
COOLANT(F) 203
IAT(F) 97
IGN ADV(DEG) 29.5
ST FTRM1(%) 1.6
LT FTRM1(%) -3.9
ST FTRM2(%) -4.7
LT FTRM2(%) 0.0
VEH SPEED(MPH) 30
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.720
ST FTRM11(%) 3.9
O2S12(V) 0.410
O2S21(V) 0.805
ST FTRM21(%) -5.5
O2S22(V) 0.735
PTO STATUS Disen
OBD2 STAT CA
FRAME: 23 TM: 73.6
MIL STATUS Off
ABSLT TPS(%) 12.5
ENGINE SPD(RPM) 837
CALC LOAD(%) 3.9
MAF(LB/M) 1.36
MAP("HG) 12.1
COOLANT(F) 201
IAT(F) 99
IGN ADV(DEG) 17.5
ST FTRM1(%) 3.9
LT FTRM1(%) -0.8
ST FTRM2(%) 2.3
LT FTRM2(%) 0.0
VEH SPEED(MPH) 22
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.570
ST FTRM11(%) -3.9
O2S12(V) 0.800
O2S21(V) 0.420
ST FTRM21(%) 0.8
O2S22(V) 0.655
PTO STATUS Disen
OBD2 STAT CA
FRAME: 24 TM: 76.8
MIL STATUS Off
ABSLT TPS(%) 13.3
ENGINE SPD(RPM) 796
CALC LOAD(%) 4.3
MAF(LB/M) 1.53
MAP("HG) 13.9
COOLANT(F) 201
IAT(F) 99
IGN ADV(DEG) 17.5
ST FTRM1(%) 1.6
LT FTRM1(%) -0.8
ST FTRM2(%) -3.1
LT FTRM2(%) 0.0
VEH SPEED(MPH) 14
FUEL SYS1 CLSD
FUEL SYS2 CLSD
O2S11(V) 0.065
ST FTRM11(%) 2.3
O2S12(V) 0.375
O2S21(V) 0.615
ST FTRM21(%) -1.6
O2S22(V) 0.530
PTO STATUS Disen
OBD2 STAT CA
FRAME: 25 TM: 80.0
  #32 (permalink)
Old 07-31-2009, 02:01 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
The numbers do look a lot better. The O'2's look like they are switching faster now. It also appears your scan tool is taking snap shots, at timed intervals. What seems odd to me, is that your MAP HG's are high when you are really getting on it, and then go low when you are cruising, and at idle. This is just opposite from every other vehicle I have scanned, and what my diagnostic information even shows for your vehicle.
This is why I am still thinking it could have a couple of wires crossed in the plug. Looking at the back side of the connector, with the locking tab up. The wire on the right side is the PCM negative, the center wire is the signal wire, and the one on the left is the PCM 5 volt reference wire.
  #33 (permalink)
Old 07-31-2009, 02:08 PM
Is there a way to probe the wires with a Voltmeter to see what its reading/showing?
I can do this if there is a way to do this. It does seem to be taking snapshots, its a Actron Scanner.
Bryan
  #34 (permalink)
Old 07-31-2009, 02:28 PM
My 2 cents worth
Wiki Edits: 3
You can back probe them with a needle, and your volt meter ground lead hooked to a good ground, set your volt meter to read 5 volts DC, and back probe the wire on the left, it should show 5 volts with the key on engine off. Then switch your volt meter to the OHM's setting, and Ohm the wire on the right to ground, it should be read 0 OHMs. Now set your meter back to volts DC, and back probe the center wire, it should read 4.5 to 5.0 volts at sea level, to 3.0 to 3.7 at 9000 to 10000 feet.
  #35 (permalink)
Old 07-31-2009, 02:58 PM
Thanks man. I will try this when I get home tonight.
Bryan
  #36 (permalink)
Old 07-31-2009, 03:19 PM
My 2 cents worth
Wiki Edits: 3
I was just thinking Back Probe that center wire with a long enough wire lead to go inside of your truck. Find a good ground inside, and check the MAP signal voltage while driving your truck. It should stay down around 4.0 volts at cruise, or steady throttle speeds, the same as idle.
This is when your engine is building it's most vacuum, and at your altitude, which is close to mine, it should be real close to 4.0 volts. If it does, it may just be a quirk in the software of your scan tool, showing that opposite reading from normal.
It will be very interesting to see what you have found with these tests.
Stephen
  #37 (permalink)
Old 08-05-2009, 03:52 PM
My 2 cents worth
Wiki Edits: 3
Have you had any luck yet?
  #38 (permalink)
Old 08-06-2009, 09:38 AM
Hey man,
Sorry about that. I have been really busy, and not had a chance to test it out. I am going to try to get the voltages on it tonight to see what happens. I had a few other things come up that I had to do, so I did not get a chance to mess with it yet.
I will make sure to try tonight, or tomorrow by the latest then let you know.
Bryan
  #39 (permalink)
Old 08-06-2009, 10:23 AM
My 2 cents worth
Wiki Edits: 3
Originally Posted by bry21317
Hey man,
Bryan
I know how THESE OTHER THINGS can mess up your time. I have been having both business, and personal problems lately myself.
Good luck!
  #40 (permalink)
Old 08-06-2009, 12:26 PM
Tell me about it, between 2 kids, wife and a friends boat I am also working on, and all my other normal crap to get done. I did not get a chance to mess with it, oh and don't forget te beers lol.
I will try tonight for sure, to get some readings on the voltage.
Bryan
  #41 (permalink)
Old 10-02-2011, 05:55 PM
Sorry to revive this thread, but I have the exact same symptoms.. I assume the new MAP either fixed the problem or the guy gave up. Maybe he will report back..
  #42 (permalink)
Old 10-02-2011, 05:59 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Hmm, his last log-in was August 2009. You might try to email or PM him.
Semper Fi
  #43 (permalink)
Old 10-02-2011, 07:35 PM
I sent him a PM. Thanks
Has anyone adapted a Mopar trans to Chevy engine? 383ram Transmission - Rearend 26 05-19-2009 04:31 PM
Chevy 505 Mark IV Engine? 71gtx Engine 3 04-06-2009 03:44 PM
pontiac engine to chevy tranny... markzepp820 Transmission - Rearend 7 03-13-2009 08:49 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
Chevy 5.3 V8 Small Block Engine 4l60e Trans Woody31coupe Engine 8 12-15-2005 04:37 AM
