pinging - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2007, 12:51 AM
pinging
Been in the automotive repair industry for 31 years, My son has my old 72 el camino donw in L.A. he was rear ended shortly after the 700r4 failed, a trans shop down there fixed it under the insurance. and shortly after he started complaining of an engine knocking under load, just tonight the gear reduction starter started not meshing with the flexplate. of course he wants me to diagnose the problem over his cell phone. Im thinking it is a Cracked Flexplate. any other explaination that may come to mind ?
Old 03-19-2007, 01:58 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Loose bolts on the flex-plate hitting cast? have him crawl under and check the TC to flywheel/flex-plate bolts..
ya never know about those tranny shop guys..
How hard was it hit? can he rock the crank forward and back (in,out) ? may be some engine damage as well.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-19-2007, 07:47 AM
tnsmith10's Avatar
when will it rain???
1st thing id do is unbolt the conveter from the flexplate and see if the flexplate sounds "tinny" when u tap on it with a hammer(dont hit the teeth)., if it sounds dense and solid, its not the flexplate. other than that, while the converter is unbolted, run the engine and see if the knocking is still there.
if so, the rear-ender may have killed the rear main bearing in the motor. (its the journal that that controls endplay)
also, like doc said, with the engine off, see how much, if any, the crank does go back and forth..
ill disreguard docs statement about us tranny guys.. we cant all be good tranny men
pinging and no acceleration twisted91 Engine 19 11-13-2006 12:45 AM
Rich at idle but pinging on tip in? JoeS Engine 24 02-21-2006 09:02 AM
pinging montea Hotrodding Basics 23 08-23-2005 07:35 AM
383 still pinging 72Nova383 Engine 10 12-13-2004 06:58 PM
Pinging or Knocking? granprix76 Engine 14 10-13-2004 03:34 PM
