Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinging on cruise part throttle acceleration?
  #31 (permalink)
Old 07-13-2010, 09:49 AM
Custom10's Avatar
Custom10 Custom10 is offline
my KARMA ran over my DOGMA
Last journal entry: SS
Originally Posted by kyle86
Oh also made a little J looking limiter plate out of some scrap kind of like the pic Cobalt327 posted. I took about half the travel out. I'll drive it some and see if that helps any.
Just as a note on this to point something out, if the current setup is working for you then so be it but...
Your limiter plate is on the opposite side of the can push rod than the crane part, the crane limiter sits under the other screw and limits the amount that the rod can travel back thus shortening the total travel which equates to less advance added when in operation (this effects your base timing so you need to reset it after installing the crane part) With what you have you are in effect limiting the travel of the can push rod however the can will start to add vac advance at the same time as it did before. Since you do not have an adjustable vac can set screw it would be advantageous to put the limiter on the back side as the crane one does, this will raise the effective start point of the vacuum advance coming in because the spring is preloaded by the limiter plate and therefor it will drop out sooner as well so when the engine vacuum drops on light trottle the vac advance will disappear sooner which may help a pinging issue.
