Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinging on cruise part throttle acceleration?
  #39 (permalink)
Old 07-13-2010, 06:14 PM
cool rockin daddy's Avatar
cool rockin daddy cool rockin daddy is offline
You shoulod want around 52 degrees total timing. Since most factory vacuum cans make 15-16 degrees of ADVANCE (not vacuum), 36 degrees of inital and mechanical would put you in the ball park with 15 degrees of vacuum ADVANCE. To solve your pinging, either reduce your initial, limit your mechanical, or adjust your vacuum advances. Your engine is no different than any other when it comes to timing.
