Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinging on cruise part throttle acceleration?
  #40 (permalink)
Old 07-13-2010, 06:43 PM
bubbahotep's Avatar
bubbahotep bubbahotep is offline
Originally Posted by cool rockin daddy
You shoulod want around 52 degrees total timing. Since most factory vacuum cans make 15-16 degrees of ADVANCE (not vacuum), 36 degrees of inital and mechanical would put you in the ball park with 15 degrees of vacuum ADVANCE. To solve your pinging, either reduce your initial, limit your mechanical, or adjust your vacuum advances. Your engine is no different than any other when it comes to timing.
I dont agree with adjusting the mechanical. If you limit your mechanical you're never going to get the TOTAL timing youd need if you do a wide open throttle run (WOT). I think the only thing that needs correcting is the vac advance limiting. If you take anything away from the mechanical advance you'll never get proper TOTAL TIMING which is 36'
