Pinging Or Dieseling - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-30-2010, 07:05 PM
Originally Posted by 454C10
the root of the problem is you are running too much compression for that cam.
drop the cr to 9.5:1 or install a bigger cam. That much cr needs a cam around the size of a compcam 292H. But that cam would also require a 3000 stall and 4.11 gears.
aluminum head would help but may not be enough.
maybe a set of aluminum heads and a 280H compcam would do the trick.
bigger chambers would also do it. if you are using 64cc heads then a set of 72's should drop the cr to 9.6.
When I talked to Lunati's tech support they said 10.5 would be fine with that cam. The only thing I don't have yet that they recommend is 3.73's, I'm running 3.42's now. I'm going to go after advance limiter and if that doesn't take care of it all, then I'll have to mix in some race gas..
  #17 (permalink)
Old 05-30-2010, 07:56 PM
techinspector1's Avatar
Wiki Edits: 326
I agree, no matter what Lunati told you on the phone. The timing events are 10.5/42.5/54.5/6.5
Plugging in the intake close (42.5) with the 10.5 SCR, 5.7 rod and 3.48" stroke into KB's DCR calculator, the result is 8.827:1 DCR. Way too high for pump gas in my opinion.
19nova69, way back on post #4, I asked you for information about this build. You never responded. I suspect you may not have set the squish on the motor when you were doing your trial assembly and subsequent machining and this is what is contributing most strongly to the detonation, although 8.827:1 DCR ain't gonna be too pump gas friendly either.
My best advice: Disassemble and start over.
  #18 (permalink)
Old 05-30-2010, 08:07 PM
I never did anything with the motor. This is the way I got the car. It had a dirt track race motor in it with dart 200 heads, a victor jr and some crazy cam that only made power above 3k. I'm trying to tone it down and make it somewhat streetable. I honestly have no idea what CR I have we just made a guess that its somewhere around 10 or 11:1 based on compression numbers compared to other cars with similar readings.. It's gotten a whole lot better in the last couple days after the cam and intake swap and playing with timing.
  #19 (permalink)
Old 05-30-2010, 08:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If I understand you, you now don't know what the CR is at all- so it's safe to say it could be even higher than 10.5:1.
I don't know what of the advice you've received you've put into use, but the help from detonation will come from more octane, cooler intake air, slowing the advance curve (stiffer mechanical weight springs) and limiting the total timing to something the engine will tolerate (lower the total timing by where the distributor is set and by limiting/eliminating the vacuum advance.
You can richen the carb to help matters some, but there's a limit on this as well as the timing as to just how far you can go before you start to take away too much power from the engine, have problems w/running hot, etc..
Most any other improvement will come from changing hard parts in the engine, gearing will help some.
In my opinion, the thing to do would be to pull the heads off, measure things to know where you are and make your tuning decisions based on hard facts.
Like Cole says, JMO.
  #20 (permalink)
Old 05-30-2010, 10:05 PM
automotive breath's Avatar
You can get a good idea of what tune-up the engine will tolerate like this:
Set the air fuel mixture slightly rich (both idle and main circuits), keep water
temperature ~170 - 180 degrees no hotter.
Lock out the centrifugal advance, disconnect the vacuum advance and plug
the vacuum line. Set the ignition advance to 24 degrees and test the engine
with a light load for ping. The engine will be sluggish, if no ping - increase
ignition advance 2 degrees and retest. Continue to do this until you hear
slight ping, when you do retard the ignition 2 degrees and test under various
conditions including up hill acceleration.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 08:35 PM
Dieseling rtyauch301 Engine 20 12-14-2009 07:36 PM
400ci Small Block pinging JustinBoxman Engine 3 05-18-2008 10:44 PM
pinging and no acceleration twisted91 Engine 19 11-13-2006 12:45 AM
Rich at idle but pinging on tip in? JoeS Engine 24 02-21-2006 09:02 AM
