-   -   pinging problem (http://www.hotrodders.com/forum/pinging-problem-225442.html)
chphlds 10-27-2012 08:38 AM
pinging problem
i have a 34 ford with a 86 305 iroc motor.it pings unless i add 2 octane boosters to gas.it runs so well i dont want to fool with timeing or t.p.i.
my question is will adding two small octane boosters damage anything?
327NUT 10-27-2012 09:14 AM
No it won't hurt anything, octane booster is only 1/10 - maybe 1/4 of 1% octane boost. If you use 91 octane gas and put a can of 104 boost in then you have something like 91.4 octane.....at the most. Why don't you fix the problem and not treat the symptom's, no matter how good it runs you're not timed correctly......or maybe something else.
chphlds 10-27-2012 01:27 PM
pinging
thanks for the info.will be takeing to dealer as i cant find anyone who will set up the computer to where it should be.i think it has the stock computer and was never re programed after engine modifications.
bigdog7373 10-28-2012 09:04 PM
Look on craigslist for someone who can tune. Also a lot of guys use "pcm for less" i've heard they do good work. An 80s engine shouldnt ping
chphlds 10-29-2012 04:15 AM
thanks for the info.appreciate it.
