pinholes in top of piston - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2011, 10:44 PM
I took the heads off my 388 because they have bad valve guides. I noticed on piston #3 there are 5 very small pinholes in the KB Hyperutectics. Do I need to replace these or just run them as is? They are not deep at all. Im hoping to be able to run them until next year when I can replace with forged....Or should I just do it now?
Old 03-12-2011, 11:02 PM
When you say "pinhole" I'm assuming they aren't right through and are just small indentations. In that case I don't see why you couldn't run them till next year. If they actually go right through I think the blowby could be excessive for the engine. Wonder what caused it?
Old 03-12-2011, 11:08 PM
Yes they are just small indentations. I did a leakdown test on all cylinders before taking heads off and this particular cylinder had the best leakdown percentage of them all at 5%..
I'm guessing detonation did this as this was one cylinder showing a little lean
Old 03-13-2011, 06:48 AM
Originally Posted by F-BIRD'88
They could be detonation peck marks but the raised edge looks more like something got in there between the head and piston.
Closely inspect the piston ring lands and piston pin bores and connecting rod bearings (shiny and or loose fit in cap) for even minute stress or distortion.
Shiny piston ring end gaps edges indict ring butting from detonation.
This tends to scuff the cylinder walls and distort/crack the ring lands.
Needs more top ring end gap.
Oil in the combustion chamber will create detonation. So will excessive timing, compression ratio and or low octane fuel.
Smooth the raised edge if you are going to reuse.
You can get those pistons in singles. A new set are cheap.
You need better cylinder heads not forged pistons.
Thanks. Plans for next spring are to put AFR 195's on it and was hoping to not pull the engine for anything. Guess I'll just run these pistons for now and pull it next spring to get rid of these KB's and put the new heads on.
How to fix pinholes in welds? Bluesbrother Body - Exterior 6 05-18-2009 08:46 AM
Using lead to fill pinholes xpsyclonex2002 Body - Exterior 9 03-17-2008 08:57 AM
Pinholes in single stage over FG Grogetter Body - Exterior 4 09-04-2006 07:23 PM
Pinholes in clear in 2nd-3 coat Bee4Me Body - Exterior 7 04-30-2006 12:11 PM
Finding pinholes, imperfections. kenseth17 Body - Exterior 1 11-18-2005 05:58 AM
