Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinion angle
Thread: Pinion angle
Old 05-05-2013, 11:50 AM
delawarebill's Avatar
delawarebill delawarebill is offline
angle of a dangle
rule of thumb.. use an angle finder on the trans on a flat spot. like the pan. find that angle then set the finder on the flat part of rear input of U joint and tilt it up that same number.. so in your case the trans is down 5 the input of rear should be 5 up.
