I set the pinion angle on my Chevelle yesterday , the transmission out put is 2 degrees down and I set the pinion angle at 2 degrees up on a 9 inch Ford rearend. Just checking to see if I did this right. I not 100 % sure
Thanks , Gene
You should be OK.. But If your going to run it hard, Some people would like to have it at level if the tranny is 2* down.. So it would cancel out when you get down on it..
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
