pinion angle ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2011, 05:44 PM
BigBlockT's Avatar
Last journal entry: recessed lisence plate
pinion angle ?
sugestions on pinion angle in a 4-link rod ?
Old 04-06-2011, 06:21 PM
equal to your driveline angle [engine/trans] generally about 3* loaded[at finished ride height]
Old 04-06-2011, 07:44 PM
Wiki Edits: 49
Just match your trans angle (in reverse) and you should be good to go. However there is no reason with a 4 link to pre-load the pinion angle as some drag racers will do with leaf springs because with a 4 link the angle shouldn't change as the suspension travels, even under load.
Centerline
HotRodsAndHemis.com
Never pick a fight with an old man. If he is too old to fight, he'll just shoot you. - Anonymous
pinion angle up or down? db flyer Transmission - Rearend 15 01-15-2011 07:25 AM
pinion angle ssonny34@yahoo.com Transmission - Rearend 1 04-03-2009 12:25 PM
Pinion Angle ? JDracing57 Suspension - Brakes - Steering 5 12-17-2008 12:52 PM
Pinion Angle? Again? oldskools10 Transmission - Rearend 7 01-27-2007 01:48 PM
Pinion angle pace69 Transmission - Rearend 6 01-21-2005 07:46 PM
