-   -   pinion angle (http://www.hotrodders.com/forum/pinion-angle-230458.html)
57SteveChevy 03-08-2013 05:33 PM
pinion angle
1 Attachment(s)
I am new to the site and am in need of some help! I have a 57 3100 and I am installing a 79 Camaro rear end, my question is, does anyone know how many degrees of angle to set the pinion at keeping in mind that my truck still has the stock height and stock leaf springs? Thanks for any help you can give me in advance!! :confused: I am attaching a picture of what the angle looks like now at 3 degrees, let me know what you think!
2speed_1 03-08-2013 05:54 PM
pinion angle
It will be fine as long as its 3 degrees down. most rear ends have that built into them already (angle of leaf spring perch).
evolvo 03-08-2013 07:17 PM
Some light reading to get you started
http://www.iedls.com/asp/admin/getFi...&TID=28&FN=PDF
SSedan64 03-08-2013 10:37 PM
Pinion angle
Pinion Angle - Wolfe Race Craft
57SteveChevy 03-09-2013 10:38 AM
Good morning everyone! this morning, the angle on my transmission is between 2 and 3 degrees down, the angle on my pinion is between 3 and 4 degrees down. I tacked the perches on level with a 3 degree angle up but now installed these are the results, looking at these I am thinking I need to reweld the perches level with a positive angle of 8 to 9 degrees to level the line from trans to pinion, any thoughts? Thanks again for the help!!
57SteveChevy 03-09-2013 10:41 AM
pinion angle
2 Attachment(s)
here are pictures of the trans angle and the pinion angle this morning!
RWENUTS 03-09-2013 12:27 PM
Make them equal. Tranny 3* down, pinion 3* up.
Your rearend needs to come up 6*.
When setting up a new rearend don't tack the perches on until you have the rearend sitting at ride height on the ground. Set the pinion angle, tack it into place, remove and finish weld.
Here's a link on pinion angles.
Pinion angle? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
