pinion angle
It will be fine as long as its 3 degrees down. most rear ends have that built into them already (angle of leaf spring perch).
Good morning everyone! this morning, the angle on my transmission is between 2 and 3 degrees down, the angle on my pinion is between 3 and 4 degrees down. I tacked the perches on level with a 3 degree angle up but now installed these are the results, looking at these I am thinking I need to reweld the perches level with a positive angle of 8 to 9 degrees to level the line from trans to pinion, any thoughts? Thanks again for the help!!
Make them equal. Tranny 3* down, pinion 3* up.
Your rearend needs to come up 6*. When setting up a new rearend don't tack the perches on until you have the rearend sitting at ride height on the ground. Set the pinion angle, tack it into place, remove and finish weld. Here's a link on pinion angles. Pinion angle? - The 1947 - Present Chevrolet & GMC Truck Message Board Network |
| trans. angle /pinion angle adjustments ? | rf9763 | Transmission - Rearend | 6 | 09-24-2011 02:02 AM |
| pinion angle ? | BigBlockT | Transmission - Rearend | 2 | 04-06-2011 07:44 PM |
| pinion angle | ssonny34@yahoo.com | Transmission - Rearend | 1 | 04-03-2009 12:25 PM |
| Pinion Angle? Again? | oldskools10 | Transmission - Rearend | 7 | 01-27-2007 01:48 PM |
| Pinion angle | pace69 | Transmission - Rearend | 6 | 01-21-2005 07:46 PM |
