Pinion angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2013, 07:47 AM
Pinion angle
Hi there
Just checked my pinion angle it is 4 degrees down! My tailshaft out of
Gearbox is down 5 degrees obviously this is wrong, would axle shims
Correct this?
If so how many degrees am I looking at?
Thanks in advance!
Old 05-05-2013, 08:13 AM
RWENUTS's Avatar
This link and chart should help.
Pinion angle? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Old 05-05-2013, 11:50 AM
delawarebill's Avatar
angle of a dangle
rule of thumb.. use an angle finder on the trans on a flat spot. like the pan. find that angle then set the finder on the flat part of rear input of U joint and tilt it up that same number.. so in your case the trans is down 5 the input of rear should be 5 up.
Old 05-05-2013, 12:14 PM
techinspector1's Avatar
Wiki Edits: 326
My thinking through the years has been to leave a degree or two between the two, so that as power is applied to the tires, the pinion will rise a little and the two angles will be very close together. Like, if the trans shaft is 3 degrees down bubble, I might put the pinion in at 1 degree up bubble. Like I said, under power, the pinion will climb the ring gear and the two should be pretty close to equal.
The Following User Says Thank You to techinspector1 For This Useful Post:
tresi (05-05-2013)
Old 05-05-2013, 12:17 PM
Wiki Edits: 326
Originally Posted by dave350v8 View Post
Hi there
Correct this?
Thanks in advance!
I'd be re-positioning the engine/trans to get closer to a 3 degree down bubble if using a carb or as close to zero as I could get with an EFI system.
Old 05-05-2013, 02:44 PM
sedanbob's Avatar
Since you asked about shims, I am assuming your rear suspension is leaf springs - if that is the case, I agree with Techinspector1's first comment about setting the rear pinion a couple of degrees down from where you want it.
Old 05-06-2013, 12:34 AM
Thanks for your comments guys,
Looks like im going to have to use about 8 degrees shims then, are there any issues using this large angle shim? if so shall I re-weld perches in a better place,
Yes im using leaf springs
Thanks again
Old 05-06-2013, 07:28 AM
S10xGN's Avatar
Gotta love a turbo!
I have 8 shims in my Maverick, got them here. This was due to letting a friend weld the perches on "at his discretion" instead of specifying a setting. Car has never had a problem with it...
Russ
Old 05-06-2013, 07:54 AM
Thanks for that, didn't fancy cutting them off again...
Old 05-07-2013, 10:58 AM
Ideally, you want the angles out of the trans to equal the angles going into the rearend, during the timeframe at which the u-joints will spend most of its time.
If its a drag car, you want the angles equal while at WOT, if this is a highway cruiser you want the angles equal while at cruise.
Sometimes you have to compromise.
peace
Hog
Old 05-07-2013, 12:42 PM
life is a temporary assignment
The change in suspension depends a lot on the type of suspension your using... I set up pinion angle's to the suspension I'm using... Some change way more then others...
On your's If your down 5* I would set the rear end up 3* to 4* because of the leaf springs..
trans. angle /pinion angle adjustments ? rf9763 Transmission - Rearend 6 09-24-2011 02:02 AM
pinion angle up or down? db flyer Transmission - Rearend 15 01-15-2011 07:25 AM
need help with pinion angle cierra1 Introduce Yourself 2 01-07-2008 05:30 AM
Pinion angle pace69 Transmission - Rearend 6 01-21-2005 07:46 PM
pinion angle mad55chevy Transmission - Rearend 3 09-09-2003 05:55 PM
