Pinion angle, modded '68 Mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2011, 10:33 AM
The 393 stroker and T5 in my '68 Mustang are angled down (towards the rear) at 5°. This is as high as I can get the tailshaft under the trans tunnel due to the slightly increased height of the T5.
The Currie 9" rear, a new custom rearend, sits on stock Eaton GT springs with no blocks or modifications. The pinion points downwards at -2° towards the front. This is clearly not great, so I tried some wedges under the spring perches to help. I got the pinion up to +4° with some 6° wedges, but they raised the rear too much and it fouled the wheelarches and exhaust on full travel.
So I have a pair of new perches from Currie, and am about to cut off the old ones (one at a time, after some very careful measurements) and weld the new ones on to give me a pinion angle of +4.5°, giving a little allowance for torque reaction.
This mod will leave the driveshaft at nearly horizontal, maybe going a little negative when the car is loaded. Anybody see any problems with this - I'd be very grateful for thoughts?
Car is for street use only, no drag racing.
Old 02-20-2011, 02:24 PM
ericnova72's Avatar
More for Less Racer
Only 1/2° for torque reaction in a leaf spring set-up is awful low, I would recommend a 2-2.5° difference because leaf springs naturally have lots of flex. To put it in perspective we run 5-7° in a drag race application.
Old 02-20-2011, 04:11 PM
Thanks - but what an idiot, I forgot to mention the Traction-Master bars, which will reduce the torque reaction a bit.
pinion angle up or down? db flyer Transmission - Rearend 15 01-15-2011 07:25 AM
Help setting 68 Mustang pinion angle onpyramid Suspension - Brakes - Steering 3 11-05-2009 02:17 PM
So its ok to set pinion angle with.... Hogwild Transmission - Rearend 1 02-25-2008 09:48 PM
Pinion Angle 6.5% JohnTN General Rodding Tech 23 11-15-2006 09:48 AM
pinion angle supernova71 Hotrodders' Lounge 2 05-23-2003 06:05 PM
