Pinion angle question (4 link) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2006, 04:26 PM
I'm restoring a 56 chevy and installing a parallel 4 link suspension. I have lowered the car to a 4 inch ground clearance. In doing so, my pinion sits a bit higher than the transmission tunnel. I figure I'll have to definitely have 2 driveshalfs. The difference from the transmission center to pinion center is a guesstimated 5-6 inch difference. Can the angle of the pinion be straight forward or will I have to tilt it down a bit. If so, how much (in degrees)?
Old 09-05-2006, 05:00 PM
Guest
You might want to check out this link....
http://www.2quicknovas.com/happypinions.html
4 Link with Track bar Question.. DV8 Suspension - Brakes - Steering 41 02-07-2008 04:49 PM
Offset rearend and pinion angle murrsue Transmission - Rearend 5 05-19-2007 05:51 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 07:58 AM
spring perch to pinion angle pace69 Transmission - Rearend 1 02-10-2005 08:44 PM
pinion angle supernova71 Hotrodders' Lounge 2 05-23-2003 06:05 PM
