Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pinion angle setup
  #25 (permalink)
Old 11-02-2011, 02:48 PM
MARTINSR MARTINSR is online now
Originally Posted by 5 CWT
I ran a street car with 580 bhp,changed the rear end several times for better gears and suspension set ups including stick axles and jag irs,always kept the pinion angle at 0 degrees and never had a problem!
One of the first lessons I learn long, long ago as a youngster just because "it has worked" doesn't mean it's right. You could have lucked out, or you could have not known if it was exactly 0 degrees. What ever the case when automotive theory is telling me to set them at a couple of degrees, that is what I will do.
