My point was that the trans and pinion angles will not change, but their angles with the driveshaft will become larger as the car is raised - which is not good for the universal joints. |
If you asked 10 tyipcal street rodders how to set up a pinion angle, only two would get it right. The reason.........because so much mis-information is put out as fact on forums such as this. Instead, try going to a reliable source for info such as just about any GM rear drive, shop manual, a custom drive line shop, or others in the business of drivelines. Inland Empire Driveline has been supplying custom length drive lines for many years, here's what they say about pinion angle:
http://www.iedls.com/Education-Zone.asp?CID=3 Do a Google search for drivelines and get your info from those in the business and not from a thread such as this one which is full of misinformation. Jim |
Brian |
Centerline HotRodsAndHemis.com "Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen |
Until I read Centerline's last post I was going to be surprised we even made it this far without refering to harmonic cancelation and phasing ha ha ha ha ha ....
In the 60's 70's those cars that were jacked up in the *** end.. nobody is saying they were right. Also as your (typically) then built car having a set of ladder bars under them would have somewhat kept the driveline angle relatively right depending on the variable. Notice I said relatively... Those cars were also typically sporting 60 series tires that rode oh so nice where you couldnt pick up a driveline vibration... 4x4 guys... it is a complete compromise and anyone with a lifted truck invariably accepts accelerated U joint wear... as far as vibration... Tires usually larger then 35 will omit any notable driveline vibration.
I have a Ford truck at the shop right now with some HUGE tread mud tires my God they shake the fillings out of your teeth going down the street. I don't think he is noticing any vibration from the drive shaft. ![]() Brian |
Too anal for me now guys! I have a honours degree in motorsport engineering and a distinction in technical engineering. I have proved my point. End of my posts in this subject.....
Centerline HotRodsAndHemis.com "When buying a used car, punch the buttons on the radio. If all the stations are rock and roll, there's a good chance the transmission is shot." - Larry Lujack |
I really don't understand why it's so hard to understand how to set the pinion angle..
This is what this thread is starting to look like and case y'all don't know it by now.. ![]() I really think he dead by now !!!!!!
I think the thread is valuable, it is explained many times so almost anyone can understand. I think it's of value to anybody searching the forum for pinion angle information.
Brian |
| pinion angle up or down? | db flyer | Transmission - Rearend | 15 | 01-15-2011 07:25 AM |
| Transmission / pinion angle setup | jlong | Transmission - Rearend | 5 | 06-15-2010 09:32 AM |
| So its ok to set pinion angle with.... | Hogwild | Transmission - Rearend | 1 | 02-25-2008 09:48 PM |
| need help with pinion angle | cierra1 | Introduce Yourself | 2 | 01-07-2008 05:30 AM |
| Pinion Angle 6.5% | JohnTN | General Rodding Tech | 23 | 11-15-2006 09:48 AM |
