pinion angle setup - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 11-04-2011, 12:25 AM
35terraplane's Avatar
Pinion Angle
Originally Posted by 5 CWT
Too anal for me now guys! I have a honours degree in motorsport engineering and a distinction in technical engineering. I have proved my point. End of my posts in this subject.....
Well if nothing else, if no one knows how to setup the pinion angle, we all know it doesn't take much to get a degree in Motorsport Engineering or technical engineering in th UK.
I'm sorry my bad, lock her up.
Bob
After 3 pages and the op doesn't get it something has to be said to lock it up.
  #47 (permalink)
Old 11-04-2011, 10:17 AM
pinion angle
the face of trans out and diff in useing a angle gauge should be no more than 5dgrs different.,trans and engine can be to the left or right of the diff aslong as faces within 5dgrs.this info came from a dana service manual.
if engine and trans moved it must remain paralelto diff.It can be lower higher just get angles within the 5
  #48 (permalink)
Old 11-04-2011, 02:35 PM
Wiki Edits: 49
Originally Posted by 35terraplane
Well if nothing else, if no one knows how to setup the pinion angle, we all know it doesn't take much to get a degree in Motorsport Engineering or technical engineering in th UK......
Boy, if that ain't the truth!
Centerline
HotRodsAndHemis.com
"The difference between genius and stupidity is that genius has its limits." - Albert Einstein
pinion angle up or down? db flyer Transmission - Rearend 15 01-15-2011 08:25 AM
Transmission / pinion angle setup jlong Transmission - Rearend 5 06-15-2010 10:32 AM
So its ok to set pinion angle with.... Hogwild Transmission - Rearend 1 02-25-2008 10:48 PM
need help with pinion angle cierra1 Introduce Yourself 2 01-07-2008 06:30 AM
Pinion Angle 6.5% JohnTN General Rodding Tech 23 11-15-2006 10:48 AM
