Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinion angle shims
Old 05-13-2013, 10:47 AM
timothale timothale is online now
Wiki Edits: 27
locked ?
Will the spring tie bolt head be long enough to hold them in place and still locate in the spring mount. One of my trailers does not have spring locating pins and I have had axle shift from hitting some bad pot holes. One time I had a come along holding the axle in place until I could get it unloaded and reset the axle and use a cheater bar to retorque the U bolts.
