Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinion angles...
Old 01-04-2005, 08:45 PM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
pinion angle
pinion angle should be pointed down 2 to 5 deg depending on horsepower. when you launch the car the pinion should come up in direct line with the drive shaft.
i have read several articles saying both pinion angles should be the same. i am not going to argue the point. all the drag racers i know all set the rear angle and don't worry about the front one. your choice.
