The pinion angles should be the same at both ends of the driveshaft.
Are you getting any vibration or "U" joint wear?
Ontario Rodders |
pinion angle
pinion angle should be pointed down 2 to 5 deg depending on horsepower. when you launch the car the pinion should come up in direct line with the drive shaft.
i have read several articles saying both pinion angles should be the same. i am not going to argue the point. all the drag racers i know all set the rear angle and don't worry about the front one. your choice. Last edited by bracketeer; 01-04-2005 at 08:54 PM. |
Drag cars are set up for constant acceleration and axle twist................street cars are not.
Ontario Rodders |
Re: pinion angle
For street use the angles should be parallel. If the trans angle is 3* down the pinion angle should be 3* up as in this drawing from the Inland Empire Driveline web site. Centerline Last edited by Centerline; 01-05-2005 at 08:19 AM. |
What lead me to the problem was the vibration
when I got on it, wicked doesn't begin to come close to discribing it... So for my lunch hour today I spent a bit of time gathering data at work today, basicly going around measuring pinion angles of various vehicles in the parking lot. Most of them were stock, but a couple are somewhere between mild and wild street cars, one of them is the equivilent of the Capri, it's a mid '80s Mustang with a 347, T5, and 3.70:1 gearing, his pinion is set at 6* down, while the tranny is 2.5* down, so I think I'm on the right track, all I have to do is find/build a 13* shim, I'll let you know how it goes... SteveL |
