pinion bearing preload tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 09:07 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Will this work? Lol torque is weight * distance so I need 14in/lb and I stole one of my moms 2lb jogging weight things. So if I place the weight 7" from the center of the pinion nut wont it be exerting 14in/lbs? I'm trying to upload a pic from my phone and its not cooperating. I'm trying to get the pinion bearing preload set for my 9" and the Yukon rebuild kit says 13-15in/lbs. Thanks for any input! I have a very small piece of wood bolted across the u joint that I place the weight on.
Old 01-14-2012, 11:01 AM
Listen and Learn
Wiki Edits: 7
success!!!
Old 01-14-2012, 01:19 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Torque is actually force times radii. And it is only an accurate calculation if the force applied is at a 90 degree angle, otherwise the force is multiplied or diminished.
The way you are going about it is not going to be accurate no matter what weight and distance you working with. Get a needle inch pounds wrench and do it right.
Old 01-14-2012, 01:22 PM
Listen and Learn
Wiki Edits: 7
Yeah... I had a feeling. Can I use a beam deflection style wrench?
Old 01-14-2012, 01:44 PM
LATECH's Avatar
Yeah, thats what you want.
Old 01-15-2012, 10:42 AM
Listen and Learn
Wiki Edits: 7
any suggestions? I really don't need one that goes much over 30. Only rearends I rebuild are GM 10 bolts, ford 9" and 8.8. Most I see go from 0 to 150 which i think will be hard to justify the difference between 12 and 15in/lb on the gauge.
Old 01-15-2012, 11:33 AM
LATECH's Avatar
Try a park TW 1 1/4 drive wrench or an Allen 2955-Wr 1/4 inch drive.
With a smaller range the ACCURACY of a low torque application will be much better and easier to acomplish .
Obviously you will need to get 2 adapters to get back to a 1/2 size for the socket needed to turn the pinion, but they are available too.
I think the KD tools 2955 is the same as the allen also.
Old 01-15-2012, 11:46 AM
Listen and Learn
Wiki Edits: 7
Awesome thanks! ill order one today. My rebuild kit says 13-15in/lb of preload for the pinion bearings... but my richmond ring and pinion dvd say 20 to 25in/lb.... I imagine the dvd is for their rebuild kit. but I should probably follow the specifications from my yukon rebuild kit. Also my rebuild kit doesn't have a specification for the ring bearing preload. But the richmond dvd says 15 in/lb. What do you think I should preload them to?
Old 01-15-2012, 11:55 AM
LATECH's Avatar
I would use the richmond spec for the pinion bearing preload.
Carrier bearings need a certain preload as well as being in the correct backlash value.
If you are changing the carrier (to a yukon I presume) then you need to setup the side bearing preload , and then change shim amount from side to side to get the correct backlash.
Once again refer to the manufacturer spec for both.
Old 01-15-2012, 11:56 AM
Listen and Learn
Wiki Edits: 7
Awesome! thanks again!
Old 01-15-2012, 02:03 PM
I would think the 25 in. lb. would show for new bearings and the 15 in. lb. for used bearings. I personally never set a new bearing at less than 25 in. lb. + - 2 in. lb.
Ford 9 " Pinion Bearing Preload dbilski Transmission - Rearend 5 10-05-2010 05:08 PM
Pinion bearing preload too tight? noise? kyle86 Transmission - Rearend 12 08-18-2010 06:40 PM
Ford 9" Carrier Bearing Preload Help dsmith1279 Transmission - Rearend 3 07-30-2007 12:40 PM
Carrier bearing preload? Sixshooter Transmission - Rearend 11 11-10-2005 11:35 AM
73 corvette pinion preload reegeemon Transmission - Rearend 2 11-16-2002 12:37 PM
