pinion depth - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2008, 10:49 AM
pinion depth
OK so as I wrote in my other thread titled "mini spool" I got a 3 series carrier with 373 ring and pinion from a mid 90's astro van that I want to install in my 82' cutlass supreme. I know about the difference in the axles 26/28 spline. my question is how do I know what to set the pinion depth at? I has a good magnetic base dial caliper to measure it, but how do I know what to set the new one to??
Can I just measure the depth of the pinion thats in there now and set the new one to the same hieght, or will I hafta change the depth due the the gearing swap?? I am new to rear ends, and have NEVER fully changed a ring and pinion. I'm more of an engine builder myself, but I know it all must work together to reach its full potential, thats why this swap must be made.... The gears that are in there now aren't near enough for my big cam and 3500 stall.. Any advice would be appreciated!!
Old 12-21-2008, 11:05 AM
BOBCRMAN@aol.com's Avatar
As a novice. Your best bet is to set the pinion up on the stock pinion shim that was in the carrier. Then use gear marking compound and check for contact pattern. Adjusting pinion depth and side gear lash till you get acceptable results. Get a book on the subject and READ!. Not a job for a novice, but with a bit of time and common sense will work.
Old 12-21-2008, 01:28 PM
If you are getting "new" gears not just new to you. The new pinion should be plainly marked with the proper pinion depth....Usually marked with an engraver on the pinion end.......
Old 12-21-2008, 02:14 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Often listed as a + or - symbol. That plus or minus the factory standard. Gears are easy, just remeer that you WILL have together and apart more times than you will want too. Sometimes it takes me 12 or 15 times sto get it right. Just part of the game. Also remember any deviating form how you assemble it, like torque reading or feel or anything wil change your final readings. Sometime you check the same shims several times that one day just to make sure it the right direction much less the right pack. It's a pain but remember it will be worth your patience.
Old 12-21-2008, 09:16 PM
prostreet6t9's Avatar
Differential/Driveline
Normally the + or - is on the Spicer gear set's and is very handy. The Pinion depth that is marked on the end of your pinion won't do you any good unless you have a pinion depth tool.Just start with your original shim and work from there.
Old 12-21-2008, 11:39 PM
pinion depth
If you are taking out a set of gears there is a plus or minus marked on the old gear. There is a plus or minus marked on your new gear. If your old pinion was a plus 10 and your new pinion is a plus 15 you would remove .005 thousandths of shim. If your old pinion was +10 and your new one was 5 you would add .005 to your old shim pack. It is that easy. The plus 10 means you are .010 thousandths over the center line of your pinion depth. Centerline is 000. That is why the pinions were marked at the factory in the first place. If you set the pinion depth, then set your ring gear backlash and bearing preload you should come out right nearly all of the time. By changing your backlash you should be able to make any further changes needed. I have set up rear ends for years and that is the way i was shown by Eaton, Spicer and Rockwell gear schools.
Good luck
Old 12-22-2008, 11:08 AM
Good luck
The OEM GM gear sets don't have the plus or minus marked on them,It would be nice if they did though.
Old 12-22-2008, 12:36 PM
The pinion depth shim goes with the housing, in general. And in the end, all that matters is what the pattern looks like. If you dont like pressing the bearing off and on the pinion you can get or make a setup bearing to slide on, or you can shim under the pinion cup(race) if you have access to various shims. It is also somewhat hard to set up a used gear since the patterns will not ever look like the ones in the instructions. Pay more attention to the coast (less worn) side of the ring gear.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 10:02 PM
Setting ring & pinion, chevy 12 bolt BUFFALOBILLPATRICK Transmission - Rearend 10 11-23-2008 09:48 PM
Problem setting up guts of ten bolt rwruther Transmission - Rearend 18 08-30-2007 11:07 PM
Pinion Angle? Again? oldskools10 Transmission - Rearend 7 01-27-2007 02:48 PM
Pinion depth guage johnnya Transmission - Rearend 8 11-03-2004 05:42 PM
