Pinion Depth Tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2013, 07:19 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Pinion Depth Tool
I am getting ready to put the 8.8 together for my olds cutlass in a couple weeks here. What do you guys think of these tools for measuring the pinion depth?
http://www.summitracing.com/parts/rat-10006
I read the included directions and it makes perfect sense how it works.
Anyone have experience with these?
Thanks
Shane
Old 06-13-2013, 08:44 PM
big gear head's Avatar
High Performance Rear Ends
Yea, I have experience with them. Save your money and spend it on something that you really need. Set the pinion depth by reading the contact pattern. That is the ONLY correct way to do it. A pinion depth tool will get you close, but the contact pattern is always the final word. If you can't read a contact pattern then post pictures here and we will read it for you and tell you what you need to do.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Crosley (06-13-2013), zildjian4life218 (06-14-2013)
Old 06-14-2013, 08:43 AM
I have this tool. I hardly use it. I did use it the other day to set up a used gear in a Ford9. Adjusting the depth to the pattern is required so using the depth tool is redundant most of the time.
T&D Machine Products 11001 Deluxe Pinion Depth Checker
Old 06-14-2013, 08:46 AM
Imsport, I had that same tool and every time I used it I always had to go back and change the shim after reading the pattern. It was always off by at least .003 inch. I got rid of it after a while.
Just start out with the shim that came off of the original pinion gear and read the pattern. Make adjustments from what the pattern tells you. It will usually be pretty close the first time and it shouldn't take more than 2 or 3 shim changes to get it right.
The Following User Says Thank You to big gear head For This Useful Post:
Old 06-14-2013, 12:52 PM
Listen and Learn
Wiki Edits: 7
I am replacing everything in the rear end besides the housing. New gears, differential unit, bearings, seals, shims, etc... Will that procedure still get me ball park to run a pattern and see how it looks?
Old 06-14-2013, 12:57 PM
Yes, just take the original shim off of the pinion that you remove from the rear end and use it, or measure the thickness and use a new shim the same thickness. That should get you close on the pinion depth. Then the pattern will tell you what you need to do from there. You will have to shim the differential to get the backlash set. Most of the time the original differential shims are not close enough to work.
Old 06-14-2013, 01:05 PM
Listen and Learn
Wiki Edits: 7
Alright cool. I will post back next weekend with some pictures of the contact pattern.
Thanks
Shane
Old 07-05-2013, 08:08 AM
cranky1's Avatar
Just stuck
I have a tool set that's similar to the one in post #3 and after using it and the pattern not looking quite right (maybe I didn't know what I was seeing?), I just trusted the settings the tool was giving me and have never had a set of gears run noisy. IIRC, my setting tool is a Pro Parts brand but I can't find it on the internet....
Setting Pinion depth Nasty 67 Transmission - Rearend 2 04-28-2011 09:51 AM
GM 12 bolt Pinion Depth mycars51 Transmission - Rearend 9 05-01-2009 09:01 AM
pinion depth eatonde Transmission - Rearend 7 12-22-2008 12:36 PM
Questions on pinion-depth and play deuce_454 Transmission - Rearend 2 05-14-2006 05:15 PM
Pinion depth guage johnnya Transmission - Rearend 8 11-03-2004 05:42 PM
