Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pinion gear assembly (how to shim)
  #32 (permalink)
Old 07-08-2012, 01:58 PM
bugget_jr bugget_jr is offline
Im not sure what the shim thickness was in the previous post but I think it was 0.037". Ok, im going to try out the 0.03 shim. Should the gears make noise with this setup? What should I prefer, a setup too close to the root or a setup close at the toe as this setup?
