Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pinion gear assembly (how to shim)
  #38 (permalink)
Old 07-10-2012, 12:30 PM
chieftain chieftain is offline
The pinion should be loose the entire time until the rotational torque is correct. Also the numbers you posted seems low, usually the lower numbers are for used bearings(6-15 in lbs). Usually new bearings are 15-29 in lbs...
