Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pinion gear assembly (how to shim)
  #39 (permalink)
Old 07-10-2012, 12:44 PM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
You should have to put around 300 foot pounds of torque on the pinion nut to get the crush spacer to crush. If the bearings got tight before that then you have a problem. The spacer may be used or it might have been a bad one that was made too short.
