Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinion Gear Question
Old 05-05-2004, 11:24 AM
dollybud's Avatar
dollybud dollybud is offline
Arrow Pinion Gear Question
After setting pinion gear preload, new bearings NOTE: 25 inch/pounds and setting in carriier checking backlash and gear pattern how much more torgue or how much do you tighen the pinion nut? It must be in foot/pounds but I can't seem to find it anywhere and there is nothing on the Richmond instructions, as a matter of fact it doesn't even tell you to tighen it but you must right? Thanks in advance for any help and info as usual.
