Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pinion to mount angles on a ford 9 in in a 79 camaro
Old 09-16-2003, 11:16 PM
Jared's Avatar
Jared Jared is offline
what angle should i set the leaf spring mounts at in relation to the pinion? I was told that the pinion should slope slightly down at rest so when torque is applied to the rearend the springs bring the pinion up to about level. how much does this matter? would they work just as good parallel to the pinion as at a slight slope? thanks for your help.
