Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinion offset?
Thread: Pinion offset?
Old 04-09-2013, 07:23 PM
Actionjk Actionjk is offline
I do rears for a living,almost all your rears are offset,most Chevys,1",most 9" Fords 2 1/2",some as much as 4",if you read up on driveshaft angles,you"ll find,if you line a driveshaft up perfectly,vertically,and horizontally,it will most likely vibrate,the offset on your Chevy rear is fine,make sure you have about 2 deg. difference between,trans./driveshaft and driveshaft/rear end,(up and down)and it will run smooth if everything else is good.
