Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinion offset?
Thread: Pinion offset?
Old 04-09-2013, 07:56 PM
sedanbob's Avatar
sedanbob sedanbob is offline
Side to side offset is just like vertical offset - you want some, and you want the angles at each end to be opposite. As long as your rear axle and transmission output shaft are perpendicular, you'll be fine.
The Following User Says Thank You to sedanbob For This Useful Post:
Crosley (04-09-2013)
