Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pinion offset?
Thread: Pinion offset?
Old 04-09-2013, 10:22 PM
sedanbob's Avatar
sedanbob sedanbob is offline
Easiest is probably a magnetic angle finder - cheap and available at most hardware stores. Rotate the rear until the yoke is vertical to measure that end, and the end of the output shaft on the transmission.
