Pinion question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2013, 11:33 PM
Newbie37's Avatar
Newbie 37
Last journal entry: Three months since started
Pinion question
Its time to have a driveline built and i am using a ford 9 inch rear end and gm turbo 400, yoke is in trans now i need one for rear end, this pic shows the reaer end,what kind of yoke ami looking for, what type is on it already
Old 09-21-2013, 09:18 AM
302 Z28's Avatar
This is a link to a great page with tons of information on Ford 9" axles, hope it helps.
Vince
The Following User Says Thank You to 302 Z28 For This Useful Post:
Newbie37 (09-21-2013)
Old 09-21-2013, 09:19 AM
big gear head's Avatar
High Performance Rear Ends
That rear end is probably from a Lincoln, or maybe a big Mercury. It has a flange instead of a yoke. This is only half of it. The other half is still on the drive shaft that went with it.
You can use a yoke from any Ford car or truck. The car yokes are longer than the truck yokes, and they are made for 1310, 1330 and 1350 series u joints. Your TH400 yoke may be for a 1310, 1330 or a 3R u joint. I recommend finding out which joint your transmission yoke uses and get a yoke for the rear end to match it. You are having a new drive shaft made so it doesn't matter if you use a car or truck yoke. The truck yokes are easier to find, and if you get an after market yoke it will be the shorter truck yoke.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Crosley (09-22-2013), Newbie37 (09-21-2013)
Old 09-21-2013, 10:49 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would look in the pick-a-part for a driveshaft with the flange that fits what you have. then have the driveshaft guy fix your shaft with the proper ends..Mine for example has the ford rear yoke to fit my 9 inch and a gm yoke on the front end to fit my t-400 trans..works fine..Hope you understand what I am saying..Most likely your driveline guy will know how to do this..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Old 09-22-2013, 06:47 PM
prostreet6t9's Avatar
Differential/Driveline
Depending on what series the rear of you driveshaft is.. You could get a flange yoke similar to Spicer 2-2-1379. I would need the bolt circle off your pinion yoke to give you the exact part number of what you need.
A flange yoke is usually cheaper than a pinion yoke so it may save you a little.
The Following User Says Thank You to prostreet6t9 For This Useful Post:
Newbie37 (09-22-2013)
Old 09-23-2013, 10:42 AM
1971BB427's Avatar
Your driveline builder/supplier will usually have those flanges in stock, and cheaper than getting a complete driveline from a wrecking yard. I found out the hard way, as I got a driveline for mine with that same flange for $40, and then had my driveline assembled and was told they had new ones for $35.
I'd measure the bolt pattern to ensure you get the correct pattern. (I think there's only two patterns) Then call whoever will do your driveline work, and get the flange first. Then with the flange and yoke in place you can measure center to center on U joints to get the length. After that your driveline shop can make it up with the proper joints.
On my Falcon's driveline I had a Super T10 four speed, so had a TH400 style spline up front, and a Explorer flange at the rear. Once I got both in place I found the length was the same as a 1st Gen Camaro/Firebird, so I bought that driveline for my car. Took the yoke, driveline, and flange to my driveline shop, and they charged me $43 to install two adapter joints to make it work.
Rack and Pinion question fasteddy_1947 Suspension - Brakes - Steering 6 02-19-2013 12:52 AM
Another pinion angle question yragat Transmission - Rearend 15 08-22-2008 12:18 PM
Ring and pinion pattern Question blacklabzeke Transmission - Rearend 11 09-23-2007 08:15 PM
Pinion angle question (4 link) bob barker Suspension - Brakes - Steering 1 09-05-2006 06:00 PM
Pinion Gear Question dollybud Transmission - Rearend 5 05-06-2004 07:03 AM
